plin
- Dec 30, 2010
My headphones are rated at 25 Ohms last time I checked. How much is the sound going to change? I read that it becomes more neutral. Does that translate to less bass? Like I said earlier I have no immediate plans to get the mod, but if it's that benefiticial, I might consider it.
According to Innerfidelity's measurements Denon AHD-2000 have relative low impedance BUT with a flat impedance curve and almost constant zero phase angle, quite impressive actually for dynamic cans, usually only orthos get better than that. Because of this very good impedance graph I believe that you would not gain a lot by applying the 1 ohm mod (although the impedance is quite low). I think that the amount of bass will be the same and you would not gain much more control (it does not seem to have a high mechanical resonance, but a small one about 30Hz, that needs to be damped by low amplifier output resistance). I suspect that your bass will be a tad tighter, but not a lot.
Of course all the above is just theory, so, please, ask other members in corresponding forums about their experience.
But usually, in most cases, lowering amplifier output resonance means both less amount of mid-bass and better control.
