Do you have a link for the instrumental ones?
They were both on the same page...sold out maybe?
The Instrumental L set are smaller in diameter than the Vocals (14mm to 13mm). They are also quite different sounding, both work well on the Z1R but I haven't tried the Instrumentals yet on the Solaris SE. I'll report back when I do but really loving the Vocals on them atm.Ah yes - in stock now anyway, but I will wait for your impressions on the differences between ordering these.
i recall instrumental on z1r added a good bit of soundstageThe Instrumental L set are smaller in diameter than the Vocals (14mm to 13mm). They are also quite different sounding, both work well on the Z1R but I haven't tried the Instrumentals yet on the Solaris SE. I'll report back when I do but really loving the Vocals on them atm.
personal faves with z1r (and everything really) is the spiral dots ++I haven't spent enough time with them but they definitely seem to make the sound less... 'focused' shall we say, which could convey a more diffused feeling. I personally prefer the Vocals on them because it fits well with the sound I think the Z1R was tuned with in mind.
anyone here owned the z1r and had to have the CA solaris also? same same but different etc? I love the 'enjoy the music' tuning and massive tall soundstage of the z1r! The highs are smooth which is my number one priority for highs ..only if they crack that would I then be keen to have that holographic soundstage depth .... curious to go compare the z1r now here in spain to the solaris at my local store as I remember loving the solaris vs my old sony z5s
on paper they can be very similar. but once you reach totl range, if you have the option to demo, absolutely do it. totl iems usually are very different experiences.anyone here owned the z1r and had to have the CA solaris also? same same but different etc? I love the 'enjoy the music' tuning and massive tall soundstage of the z1r! The highs are smooth which is my number one priority for highs ..only if they crack that would I then be keen to have that holographic soundstage depth .... curious to go compare the z1r now here in spain to the solaris at my local store as I remember loving the solaris vs my old sony z5s
I just sold my Solaris SE, so hopefully my impressions on both are still fresh.anyone here owned the z1r and had to have the CA solaris also? same same but different etc? I love the 'enjoy the music' tuning and massive tall soundstage of the z1r! The highs are smooth which is my number one priority for highs ..only if they crack that would I then be keen to have that holographic soundstage depth .... curious to go compare the z1r now here in spain to the solaris at my local store as I remember loving the solaris vs my old sony z5s
What source are you using it with? This matches up with my impressions via the SR25 with the Z1R (not a great pairing IMO).I just sold my Solaris SE to fund my purchase of one pair of IER-Z1R, so hopefully my impressions on both are still fresh.
IMO, these two sound really different in almost every way. The bass on Z1R is much more impressive, thicker, has more sub-bass and better texture than Solaris. Mid on Solaris is more forward and has a fuller presentation than Z1R, the male vocal on Z1R is most obviously recessed under comparison. Treble on Z1R could sound hot and sibilant with a bad pair up, I guess it is pretty sensitive and dependent on the sources as Z1R definitely requires way more power to drive. Treble on Solaris SE sounds smooth and beautiful to me no matter what source I use, while some can also find it hot. Solaris soundstage is holographic, Z1R soundstage is wider and more spatial, equalized in depth. Also I could find good sound coherence on Solaris without much effort, while Z1R is picky on sources. Just my 2 cents.
I am using SP2000 with the Z1R, and the treble is unpleasant like I described above. When I switched to PHA-3, Z1R sounds much better controlled.What source are you using it with? This matches up with my impressions via the SR25 with the Z1R (not a great pairing IMO).
That's surprising, my Z1R sounded great out of the SE200 from the AKM (balanced connection). No signs of sibilance to my ears. But saying that, I did notice some when I switched to a majority silver cable. Are you using the stock cable? Not to hijack the Solaris thread here which is a great IEM in its own right.I am using SP2000 with the Z1R, and the treble is unpleasant like I described above. When I switched to PHA-3, Z1R sounds much better controlled.
Also the foam tips or the triple comfort tips come along with the IEM could help tame down the treble.
