Yes , the silver is overall brighter . Less weight in bass . And the RC has sweeter mids to my ears . Also the pure silver got very stiff over the time .. the RC is still soft like day oneThanks for the feedback
By any chance did you try the lc-d pure silver as well? I’m torn betweent the two cables
Campfire - Solaris
- Thread starter KB
The silver cable has tighter bass and more detailed sound better separation, well it does to me anyway.I wish I preferred LC-RC because of the removable jack plugs.Thanks!
Which sound differences did you notice between the two cables with solaris?
Silver cable is very supple I have two since they where released never gone stiff etc.
- Jun 22, 2015
A high quality silver cable never sounds bright. It will revel everything that is being sent from the source.
If you are going to look for a silver cable look for OCC. It does make a difference.
Right the premium silver from 64 audio sounds way better as the fiio silver .A high quality silver cable never sounds bright. It will revel everything that is being sent from the source.
How long do you have it ? Mine got really stiff after the Y split ..The silver cable has tighter bass and more detailed sound better separation, well it does to me anyway.I wish I preferred LC-RC because of the removable jack plugs.
For me, cable based 25 AWG SPC with Litz tech, will be my choose, maintaining from mid bass weight, and Upper Treble (spark) clarity with a bit smooth. Wide and depth soundstage. With felt a bit recess in vocal, but still detail...
although I like the exotic sound of palladium based cable..
Yeah Leonidas 2 is a pure blissFor me, cable based 25 AWG SPC with Litz tech, will be my choose, maintaining from mid bass weight, and Upper Treble (spark) clarity with a bit smooth. Wide and depth soundstage. With felt a bit recess in vocal, but still detail...
- Jun 22, 2015
So is DHC Clone Silver.Yeah Leonidas 2 is a pure bliss
I need to check that one alsoSo is DHC Clone Silver.
I think you mean code 51?
Area51 is consider to try if you want Solaris to have layers of details...
Wow it’s pretty small , hows the sound compared to E01 ?
I got mail!
ah yes... my bad...I think you mean code 51?
although I prefer the cable from Arthur... Xcalibur...if I did not mispell
SBranson
I got mail!
Awaiting impressions with bated breath....
Total: 29 (members: 0, guests: 29)
