beholdclarity
Alright, alright, alright!
Since I am going to be setting my Solaris up against the Legend X in the next days, I thought it wise to keep my memory fresh regarding the other contender, the VE8. That's why I took another approach at the Vision Ears Flagship (until the Elysium, that is): Another day, another playlist.
Here's my update in regards to the VE8 on its own, without A/B testing against Solaris (my singular IEM).
Technical details
Driver tech: 8 BA Setup, in three ways, 2 lows, 2 mids, 4 highs
Cable: Very standard, nothing fancy, quite pliable, straight 3.5mm termination
Playlist: Selection of Michael Jackson, Fleetwood Mac contrasted with Progressive Metal and EDM. Mostly female or high-pitched vocals
Equipment: SP1000Cu at Volume level 60 (lower end of my usual listening volume)
The Lows:
The VE8 has quite a substantial and deep bass, with good rumble. I find it lacks vibration and does not reverberate enough to compete with DD offerings, but still. The bass is black and deep and might satisfy those who are accustomed to BA bass. The control of the bass is very good; it's not clinical or sterile but affects the mids only minimally. I do like bass guitars and like to imagine hearing the string vibrating, which I am missing with the VE8. This is unlike the acoustic guitar, which is portrayed superbly on the VE8. You can make out each individual pluck with clarity and intent.
Detail in other spectrums are never overshadowed by the bass and make for a rich detailed experience.
The mids:
I think the VE8 has a neutral-warm tuning that only appears dry and bright when compared to a very coloured IEM like the Solaris. The presentation is quite pleasant with incredible detail and energy. This, I presume, is the reason why the VE8 gets portrayed as "musical". It makes ya foot tap without ya knowin'.
The highs:
Effortless and magical. Nothing left to be desired; not sharp, not mushed, fast and energetic. The highs are so detailed and crisp, but smooth, that high-pitched details like plucks in the strings or particular elements in vocals that were previously hidden in the relatively organic/ lush Solaris are now revealed to me.
Recommendation:
This write-up wants to at least create a little value for those who came here looking for information on the Solaris. So I would like to come back full circle. Choosing between the Solaris and the VE8 is not easy, which is a testament to the technical prowess of the Solaris with a reasonable price tag.
The choice should be between these factors:
- Custom or universal. Each is available only as one option
- Price. The VE8 is significantly more expensive
- Tuning. Both are remarkable at what they do. Are you looking for a well balanced visceral bass (not in bass-head terms) with a very relaxed and smooth presentation on the warm side? Go for the Solaris. Do you prefer a well done BA bass and need more energy in the mids and highs with better PRaT? Go with the VE8
It's time again!
The Legend X
The Legend X is a well-known hybrid with 5 BAs and 2 DD (Sub-woofers) in the following configuration:
2x lows, 2x mids, 1x high-mid, 1x high and 1x super-high in a mathematically difficult to explain 10-way setup
For some reason the LX is huuuuungry for power, I have to crank up my SP1000Cu to 90 (I use 55 for Solaris)...
The Legend X is quite a bit closer to the Solaris than the Vision Ears VE8. The LX offers thick mids with superb body, which is partly because of the notorious bass bleeding into them and less so because of the mids themselves.
I don't think the bass of the LX is extreme, I have heard much "worse", so let's get that out of the way. It is uncommonly bass-heavy, however, for it's price range.
The bass should not be reviewed by me at this point, as the IEM is not and will not be burned-in properly. But it can be safely said already that the bass is nicely done. It whoops when it has to and lends bass guitars the texture and depth they deserve. Dark instruments rock and low, vibrating piano notes strike and sound with a rich timbre more than anything I have heard so far. This will take time getting used to and probably tone down a bit, but at the first listening experience that is the key component of the LX. The bass will take away from the mids and especially from the highs when both are played simultaneously, which is meh.
The mids are soft and rich with plenty, plenty of detail. Maybe something between the vocals and the bass is recessed, though.
The highs are superbly smooth but detail rich with bad, bad extension. The LX isn't capable of high piercing treble and for some that is great. I thought I would find that great as well but I am not so sure at the moment.
I also notice a bit of listening fatigue which can only be attributed to the increase in bass at similar listening volumes. My ears are sensitive (and I listen loud) but I never had fatigue due to bass before.
On tracks where there is only little bass present the LX shines remarkably, making me wonder if the bass isn't so well-done after all. Acoustic guitar strings are remarkably detailed and vocals have emotion, clarity and intimacy. They sound better than on the Solaris but may be a teensy bit behind the VE8. Incredibly, the LX is best for music where lows and vocals but no highs, or vocals and highs but no lows are present. For many audiophile classics that is true and it is also true for EDM. But, as many stated before me, it is no allrounder.
Where the LX doesn't perform in my opinion, is when it all has to come together. When lows and mids or highs have to be equally present, the lows invariably take the cake making you go "oh, too bad" because you wanted to hear it all. The LX is just not very harmonic, in my opinion. Less so than the Solaris.
The LX goes much lower than the Solaris, with a seamlessly bottomless and thus remarkably huge soundstage, where the Solaris extends higher.
The LX is also wider than the Solaris, with a small victory for the Solaris in the positioning of instruments.
The LX rocks; meaning low instruments and drums have authority and power.
It thumps; meaning you get visceral power and immeasurable depth.
It has soul; meaning vocals are clear and full of emotion.
It sings; meaning guitar strings have soul and magic in the lower treble.
It is fun, but I fear the V-shape is too pronounced.
It doesn't clap and kick and it doesn't sparkle in the highs, because it lacks treble extension. Super-high vocals sound awkward and cymbals have no definition and sparkle.
It is not cohesive, things don't just fall together when they should.
It kind of lacks magic.
I am very surprised how well the Solaris holds up in this battle against two TOTL contenders with higher price points. Most of it comes down to personal preference with no obvious flaw for any of those, making the Solaris an excellent choice for all those who still consider purchasing it.
You're not going to get better. Just different.
