Malevolint
I really have a hard time understanding what this term 'technicalities' refers to. Reminds me of the famous Mark Twain comment-- "apparently Wagner's music is better than it sounds". The job of a speaker/headphone/iem, is to convert the electrical signal it is being fed, into the correct air motion that created the recording in the first place. (Or, the voltages that were recorded from electronic sources). It either gets it right or it doesn't. If you recorded a sax being played, then the recording should sound like that sax, being played just that way, in that acoustic environment. If the sax player farted audibly during the recording, you shoud be able to hear that fart in the recording. Bright recordings should sound bright, dull ones dull. A trasnsducer that makes all of your recordings sound the same, or makes all the sources sound the same- something is wrong with it- you may like it, if it does something you like, but it is wrong. See, didn't have to use the word 'technicalities' at all! A treble-happpy EQ curve is not detail, or resolution, it is an alteration of the intended sound--
Please, by all means, know what you like, seek it out, and enjoy it without finding the need to justify or defend your taste.
Technicalities (technical ability) refers to soundstage, separation, decay, etc.
I do seek it out and have no reason to justify my taste. I think you misunderstood my frustration with having a hard time finding IEMs that suite my taste with justification.
Thats a funny quote btw.
