MinedSafe
- Jul 14, 2013
Is that the small Island with rude people beside nice and friendly Ireland? Home of Guinness!
The home of Newcastle Brown Ale
We would need more information to guide you to the best choice:
* Is the visual appearance of the unit important ? (If yes, then the premium price of Marantz would be worthwhile to you, otherwise not.)
* Do you listen to FM radio ? (If not, then an "integrated amplifier" that does not have a tuner might be a more cost-effective choice. But if the answer to the appearance question was "yes", then you might want a receiver just for the "look".)
* Do you listen to rock and pop - or do you favor folk, jazz and/or classical ?
You mean its too loud at very low volume? you need to replace original 470om resistors for bigger ones. Not sure is it wot for Grado as tese are dynamic, low impedance eadpones.
I use ifiman E5LE, ortodynamic.
Again sorry for grammar - keyboard not working and some letters are missing.
Is that the small Island with rude people beside nice and friendly Ireland?Home of Guinness!
Ah!!!!! LOOPY JUICE!! This explains a lot.jk
Also the birthplace of one Gordon Sumner...aka Sting.
this is what we have out west....
wooof woooof
Tats very strange. I listened E5LE at 11 o clock max on volume pot wit original resistors and after messing it up wit lower value I really cant go past 9 o clock. But ortodynamic ones arent sensitive for DF generally as dynamic ones. IMO its not good combination for dynamic like Grado as you sould observe slower attack, overall mudness, big wooly bass and also some distortion on igs (soprans, sry no letter working...) like sarpness, unnatural sound etc. Its muc better to use very low impedance output for Grados. Maybe your model is not properly working - dont know. Can you describe more at wat level of volume knob you listening to and wat appens?
+1.
Yep, Kardon has those problems, but it still has very nice sound.
Does Grado require amp? I had SR325i once and didn't find amping adds large margin benefit.
If you like Grado sound, Kardon really is not good match, you may think later models of Pioneer. They generally add soundstage and dynamics. OK, I can also recommend another Kenwood Kr-8050/Kr-9050 High-speed DC stereo receiver, the sound rises and decays so fast in those models. Gees, I felt I was always forced to listen to every note. Not my taste at all, but may suit you since you dig Grados.
@scottie,
I don't drink much but the ale you posted just lure me to, maybe the name and wooof, wooof trigger me! You evil .....!!!
With enough Ale,it'll look okay!
