Skylab
Reviewerus Prolificus
That depends what you want to accomplish. If you want to use the receiver just as a power amp, and not have its volume control active, then you would go into the "main in" jacks.
er-owners/4095#post_8132780"]
if i wanted to use a pre amp with the pioneer would i use one of those? or just run the pre into the aux?
If I didn't just buy the Marantz 2500.....I'd be all over that Sansui AU22000, she's a beaut!!
i wonder how much space is between each rack? the pioneer is just shy of 7 inches tall
The fuse-type lamps are incredibly easy to replace. These are the ones I bought:
http://www.ebay.com/itm/Marantz-LED-Custom-Made-Blue-Fuse-Lamps-7-PACK-/250966474271
Just take the cover off, unscrew the small circuit board holding the lamp and holder, pop out the only one, put the new one in, making sure the LED will be facing the meter, screw back together. Done.
How's this for something different? A buddy on AudioKarma built a SET amp inside this old HP Oscillator case. To quote the builder:
"SINGLE ENDED, ULTRA LINEAR.
(6AV5's are a hot ticket TV tube, in triode similar to 2A3 specs)
STEREO, 5.5 WATT AMPLIFIER.
TV TUBE. SEUL.
SOLID CURRENT ON OUTPUTS WITH LED BIAS ON DRIVER.
SCHADE FEEDBACK, PLATE TO PLATE/GRID. (LOCAL FBK)
It uses binding posts on the front, has new rca inputs, all the supply
caps and resistors, almost everything but this classic chassis is new."
You can read more about it here: http://www.audiokarma.org/forums/showthread.php?t=376120
