wualta
Orthodynamic Supremus
- Sep 12, 2004
The AT-705 is the same headphone, but with a cost-reduced cute little transformer box, as the AT-706, which comes with a big honkin' transformer box that is styled to enhance the decor of your typical big honkin' mid-'70s receiver. In '77 or '78, Audio-Technica replaced these with the ultralight and ultraslim ATH-6 and ATH-7, respectively, with a similar difference in box sizes. BmWr75 has shown you the 705. The 706 and its box constitute a bit of a mystery, since one pair will have amazing bass but won't play loud before it distorts, and the next one will be really loud but have very little bass. The difference isn't in the box, either, so audition before you buy, etc etc.
Here's the 706. Note the resemblance to the Stax SR-X of the same period:
Now here's the successor ATH-7:
Much slimmer headset, the sensitivity switch is gone (the ATH-8 got it), you've got an overload indicator, they've moved from the little DIN plug to a larger proprietary one, and we're into the Black Era, but it's otherwise similar. The problem with the ATH-7 and its big brother the ATH-8 is the same problem Stax had with the SR-X and PMB had with... just about all the headphones they made. The PVC pad coating has all gone poof, like most foams and flexible plastics of the era. So the pads don't seal, though they're very comfy. So they're even bass-lighter than they should be. Search for a pad with a thin, supple covering and a good dense filling (the ATH-7 used stacked cotton discs), and you'll get some of your bass back.
Originally Posted by Wharfrat /img/forum/go_quote.gif
"Bass-light" is somewhat synonymous with "ATH" for that matter...haven't heard much of a change in bass-presence between closed and open backed ATH cans regardless of amp changes, though I do love their midrange, which changes from being more recessed or upfront depending on the amp.
If you do have a pair of ATH-7s with the amplifier, could you post a pic of them, for the good of the fellowship?
