Calling All "Vintage" Integrated/Receiver Owners
post-15222344
Post #18,421 of 18,539
Monsterzero
Down at Dinos Bar & Grill
Thank you. So you're using it with an HE-500. Which amp that you use to power it?
How about the volume level, do you have to use a very low volume?
IMO the HE500 doesnt need speaker tap treatment. I tried it from taps and I noticed slightly cleaner bass vs. HP jack,but nothing dramatic. The downside of taps is you have very little wiggle room on the volume between silent and blasting,whereas from HP jack you have plenty of room for volume adjustment.
HE6,Abyss,and perhaps a couple others,speaker taps is the only way to go. YMMV.
post-15222367
Post #18,422 of 18,539
musicman59
Canton, MI
Canton, MI
I am looking for a good condition analog parametric equalizer. Anybody with any leads?
Thanks.
post-15222412
Post #18,423 of 18,539
Blommen
Denmark
Denmark
I agree. But, with that said, if someone is dead set on speaker taps then the solution is a pre-amp. I use my Sony TA Z1hes as dac/pre-amp into a Sansui AU 907, which gives me very fine volume control via the Sony... I don't use speakers taps but still I would guess it applies to those as well.
Reactions: Monsterzero
post-15222635
Post #18,424 of 18,539
kid vic
Vancouver
Vancouver
YMMV. I hear a massive difference in the HE500 and LCD-3 via taps, the Ether Flow less but sufficient. On my amp (Kenwood KA-9100) I use the -10dbz switch which gives me much better volume control on the LCD-3 and flow.
I have used integrateds for this purpose everytime so I don't see why a pre power combo makes sense as the only option? If you have a pre that has certain functions or a specific sound then sure, otherwise there's no advantage I can think of.
post-15223502
Post #18,425 of 18,539
penmarker
Malaysia
Malaysia
Planars get a lot more benefit out of speaker taps because they're usually harder to drive and they have a linear impedance through the audio band. Or so I've been told.
post-15223543
Post #18,426 of 18,539
richard51
Not only that, planars are harder to drive, then they love the headphone out of vintage amplifier....But mostly, vintage amplifier love planars, because they enhance their original sound quality, without suffering or struggling with their raw direct power … Owner of a Sansui, I prefer an Ortho in the headphone out to any dynamic, except perhaps 600 ohms one...
post-15223626
Post #18,427 of 18,539
kid vic
Vancouver
Vancouver
I agree with whoever told you that. I almost prefer Planars through speaker taps over my Dynaudios through the same taps..... Almost but not quite
post-15237880
Post #18,428 of 18,539
Tacanacy
Norway
Norway
post-15237884
Post #18,429 of 18,539
SpeakerBox
I want to buy a Sansui 881 and I'm wondering if anyone would be able to tell me if it would need to be serviced if I show photos that the seller sent me. Here's the link: https://www.dropbox.com/sh/iffy1mdoz7oqh8n/AAD10JwwU7MYZ6mNWgEZR3Yfa?dl=0
I was suggested to give @petemac110 a mention.
Any piece of gear in the 40+ year old range will need a total recap and servicing. Sometimes you are lucky and it keeps working but to get the most out of it the recap and servicing is recommended.
post-15237890
Post #18,430 of 18,539
Tacanacy
Norway
Norway
Yes, but the seller may have done that. I wouldn't know the difference.
post-15237898
Post #18,431 of 18,539
SpeakerBox
From what I can see in the pics, the electrolytic caps have not been replaced.
Reactions: Tacanacy
post-15238766
Post #18,432 of 18,539
petemac110
Correcto - she's 100% original internally.
An initial service would be the first port of call for an amp of this age - checking/adjusting bias and DC offset and cleaning/lubricating switches and controls etc. If the budget allows, a proper restoration will yield the best sonic results and ensure reliable operation into the future.
Reactions: Tacanacy
post-15238775
Post #18,433 of 18,539
SpeakerBox
Of course a recap will necessitate re-adjustment of the settings - so in general it is best to recap first and then set per service manual, IMHO.
post-15238809
Post #18,434 of 18,539
Monsterzero
The 881 is a fantastic sounding receiver. The best of the six I own. Highly recommend giving it the TLC it needs and it will reward you with a nice warm,musical sound,with great mids.
post-15238922
Post #18,435 of 18,539
UntilThen
Website
www.head-fi.org
I’m sending my Sansui au Alpha 907mr for a full body works to my Sansui’s guru - Pete’s Dad. :)
Reactions: petemac110
