Anyway new update, i rigged a ground from a UK 3 prong plug with only the ground cable connected onto the ground terminal of the marantz chassis and its still humming. im guessing the phono amp of the marantz need to be checked. i mean its a 70s amp and after so many years in storage something might have gone wrong. so yea gonna find a reliable repair guy to have a look at it. and i need to turn the volume up to like 12 o clock to barely hear anything if i plug the tt into the phono stage(Over the unbearing low end hum). and even so. only the right channel have sound. i know it isnt the speakers or anything cause if i run another source through the aux in, it works perfectly. anyway thanks for all the advice! I really learn a lot.( Vintage Technics TT looks very tempting to me now )
The speakers are Aiwa SX-N990 from an old Aiwa Hifi system my family owned when i was a kid. Honestly the speakers are pretty flat compare to my Yamaha HS-8 but with the Marantz EQ i was able to get an enjoyable sound out of it. Still hunting for a pair of NS-10m though
yea only on phono. even without anything connected. and i switch to phono. it hums. on the aux channel it works like a charm.
It's pretty normal for there to be a slight hum when you switch to phono with or without something plugged in. I suspect that your ground cable job has done you no benefits but I could be wrong. If your in the UK there are a lot of brands that you can look into local to you (Rega, Linn, Sondeck for starters). Chances are that the cheapest of any of those will out perform your audio technica. However, if your not serious about throwing lots and lots of money at vinyl just skip it all together.
