Calling All "Vintage" Integrated/Receiver Owners
- Thread starter moodyrn
- Aug 25, 2013
Looks like I'll have to eat my words about not owning anything above 100W as I just snagged an Akai AA-1200 with 120 watts per channel for a cool 81 pounds
headphones1999
awesome, akai made some very nice stuff...
I think its worth fully recaping.
Congrats!
If the headphone output is anything like my little Akai AX-7600 (fully restored and recapped) you're in for a real treat!
headphones1999
Another picture i got from him at the same time, there is something that is botherng me,those parts, 50% look alright and 50% doesnt look in a doesnt look in good shape, have u guys seen something like this before?
Bob A (SD)
- May 11, 2003
A bit of thread drift. I had pulled my 1980 vintage Phase Linear 3000 Series II preamp out of storage to check the headphone circuit and posted about it in this thread (http://www.head-fi.org/t/537704/calling-all-vintage-integrated-receiver-owners/16080#post_12559107 ). I also have pulled out my vintage 1993 Philips CDC-935 carousel CD player (SAA7341 1-bit 192x DAC, CDM12.1/0 transport) which was known for a "high grade" variable headphone amplifier circuit among other things.
Typical comments found about it: "This player features the very nice Philips CDM 12 transport , which is used in some of the best CD, and subsequently more expensive CD players, an example would be the Marantz CD-17. This CDP is not your run of the mill "cheapy" CD player. It was made at a time w CD players were of great significance in a hi-fi system. This can be seen in it's build quality and the sound quality of this player. It has a phenomenal headphone output stage and sounds open, dynamic and quite musical for a CD changer."
After checking the functionality of the player (everything works as it should save the remote despite new batteries), I auditioned the headphone circuit with my HD600s. It drove them effortlessly and despite the age and ancient DAC it provided very very satisfying SQ. So much so that I moved it from storage into my home theater equipment rack where I'll use it for CDs as opposed to having my Oppo DV-980H DVD player do double duty.
As an aside I had originally retired the CDC-935 in 2003 with an Eastsound CD-E5 deck used as a transport with a dAck! v2.0 outboard TDA1545A R-2R filterless DAC which is still used in my main stereo system.
i luvmusic 2
- Aug 27, 2013
My SA-7700 is finally back from the shop after few months and WOW!What a difference after it's been cleaned and replaced all the electrolytic caps.
vapman
Member of the Trade: bhobuds.com
- Aug 14, 2006
Makes me feel like it's based on an old dynaco design or something.
Those rca jacks might be too close to each other for comfort/usual cables.
SpeakerBox
- Jan 18, 2013
Similar experience here. I just pulled my Rotel RCD 855 out of storage - 25 years old. It had problems with intermittent operation so after digging around a bit I discovered that the +/- 5V supply was toast. After a recap of the power supply and replacing the +/-5V regulators and a Zener it is up and running. It also uses a well respected Phillips transport and has a very good DAC chip. This thing now sounds fabulous and absolutely slaps my Sony NS999ES (now doing man cave duty) for Redbook playback. There are a ton of mods I could do to the Rotel and may be going down that path in the future. No HP jack though - can't have everything.
vapman
- Aug 14, 2006
I saw that exact model Rotel CD player at a flea market for $20... still regret not getting it!
I did get a Sony D5-A and a Creative Zen Jukebox that day though for $10 altogether.
SpeakerBox
- Jan 18, 2013
Ya, that would have been a deal for 20 bucks. I see them going for $200 on ebay.
i've got my marantz 2216 out of the rack, i to replace the dial pointer/indicator light, the tuning wheel is a tad sticky in one spot,
and while i have it out, i'd like to get the inside cleaned out a little better, i've blown it out with compressed air, and used a brush
but it still seems to have dirt and grime wanting to hang on.
what i have found on the subject was using denatured alcohol and q-tips, but i thought i'd ask and see if y'all had any other methods and or advice
thanks !!
thanks !!
SpeakerBox
- Jan 18, 2013
I use rubbing alcohol and q-tips. Tedious, but the best way I have found.
You can use denatured, but it does leave a residue. Don't power-up until everything evaporates.
headphones1999
its okay, worst case is that i dont need more then two source inputs anyway
a youtube video i found, said rubbing alcohol left the film, to get denatured , strange
but you haven't had that problem using rubbing alcohol huh , that i have, denatured i'd have to get
