PhoenixG
- Nov 4, 2012
Whether the term "balanced" is misleading or not is mostly a matter of context. Historically, in the days of tube equipment, very little equipment was internally balanced (although "push-pull" is a form of balanced design). However, because of the higher operating impedances of tube equipment, the connections between equipment were very sensitive to picking up hum and noise. Therefore, in the old days, most pro tube equipment used small signal transformers at the outputs and inputs to "create" a balanced signal for connection purposes. Good quality transformers worked very well for this, but were quite expensive, and so a good quality balanced input or output was considered an important premium feature on pro equipment - and one that you often paid a lot extra for - even though nobody even asked whether the rest of the circuitry was balanced or not (and it probably wasn't).
The thing you really need to keep in mind, though, is that all of this is done in the service of performance. (For example, if your DAC device has a S/N of 110 dB, which is excellent, it really doesn't matter if the Wolfson chips inside it are connected in the mode that gets a S/N of 125 dB or the mode that gets 128 dB. In a DAC, how well the power supply is designed, and how carefully the circuitry is laid out, will usually make much more difference than which mode on the chip is used.) If you have an unbalanced connection, and it's picking up noise, then switching to a balanced connection will probably help; and, if you're just putting together a system, using balanced connections to begin with will make it less likely that you'll have a noise problem; but, if you have unbalanced connections, and they're dead quiet already, then switching to balanced connections is unlikely to make any difference. Likewise, all else being equal, a balanced design may have lower distortion, but all else is rarely equal, so all that really counts in the end is the performance itself (it's quite possible for a well designed non-balanced amplifier to perform better, and sound better, than a balanced one that is less well designed).
Thanks for the history lesson! I really enjoy when audio dogma is put into perspective. I think you hit the nail on the head for this one. There are a lot of traps we audiophiles are led to to spend our $$$ on things that objectively make no audio difference. Sure something may be 'better', but is it worth it? Often the answer is no. It's like looking at a picture of the stars and saying "ah yes, Alpha Centauri is definitely 4 lightyears away in this one, not 10." Maybe a carefully calibrated machine could tell the difference if it were hooked up to the equipment that took it, but not only can I not, it is beyond impossible for any human to.
The second trap you hit on was the old $20 saddle on a $5 horse. You can spend infinite amounts on cables, power conditioners, interconnects, magic garbage, room treatments, jumpers, etc., but you've wasted it if your amp isn't well done with a good source and good speakers/phones. There is a cost/benefit to everything that seems to often get kinda bonkers. I saw a really cool system once (ML1C w/ jbl horns, MC275, beautiful) and the guy had a room that was really noisy. It's hard to even tell if it sounds good when your curio cabinet jangles, and throwing all the cables you want at it won't fix that.
