If you're trying to tell
BEFORE you buy it, and you can't find the schematic from more "formal sources", then often you can find a schematic by simply Googling "company model XXX schematic"; you'd be surprised how many schematics for vintage equipment have been scanned and posted over the years. (In general, older models used the dropping resistor, while newer models didn't - because, in modern terms, a separate low-level headphone amp is considered to do a better job. While there isn't some specific date where everyone switched over, you'll probably find that most manufacturers did switch over, so most models from each changed from one to the other at a certain date - while, possibly, higher end models switched a little sooner - since a separate headphone amp would normally be considered a more premium design.)
You can tell easily enough from the schematic. You should also differentiate between a simple series dropping resistor and a true voltage divider. A dropping resistor is a simple single resistor in series with the headphones. With a single resistor, you will get a higher output impedance, and so more interaction between the output and the headphones. (But the level will be more consistent between lower efficiency high impedance phones and high impedance phones of lower efficiency.) With a true voltage divider, depending on the values chosen, you should have a more consistent frequency response, and less interaction between the headphones and the output... and so a more consistent frequency response.
You also need to beware of making foolish generalizations....
Some units with simple-resistor outputs sound very good, but units with noisy amplifiers, and some older designs with amps that distort heavily at very low power levels, may sound awful. Also, of the units which have separate headphone amplifiers, some with discrete transistors sound very good, while some are really bad, and likewise for op amps. In other words, unless you know a
LOT about circuit design, don't assume that "a cheap op amp" will sound bad, or that "an expensive op amp" will sound good, or that "a discrete transistor amplifier" will sound good. There's a lot more involved than which op amp someone chose to use..... (there are very few op amps that I would automatically assume would sound bad, and none that I would assume would sound good).
Another thing is that the output of units with output resistors will interact heavily with your particular headphones. All of this suggests that, if at all possible, you should try to get a chance to hear how a particular unit will sound with the headphones you're hoping to use it with...
Hi,
I was wondering is there is a definitive list on which vintage Receiver Brands use cheaper op-amps for the hedphone jack. And which ones drop the speaker outputs through a 120 to 300 ohm resistor to limit the current? Is there a way to tell by opening up the unit? Would is be possible to obtain this from schematics? I have a 1979 marantz 2500 & Nad integrated from 1984.
