driver 8
- May 19, 2009
I thought it was just a Soloist with an added DAC. A whole new animal from the HA160D
The Headphone Amplifier The Conductor also features our well regarded Soloist Headphone Amplifier. We had to deploy another 35W customised transformer to ensure that the Soloist circuitry is independent and optimised at all times. This is to ensure that its performance is exactly the same as the standalone Soloist.
I know; I have both of them.
The question earlier was whether or not the amp section is any different from the Soloist (if I understodd Trogdor correctly) and it seems not to be according to their site:
so those Mjolnir vs Soloist reviews are worth checking out.
I'm using OSX10.8 and Audirvana and have absolutely no problems with Conductor. I'm powering it via the Supra Lo-Rad shielded power cable and HiFi tuning Supreme fuse (replaced original fuse in the Conductor).
For Macbook Pro connection i'm using TOSLINK and USB connection to Logitech Squeezebox Touch (with triode's Enhanced Digital Output and kernel #12 with support for [size=small] Tenor TE8802 USB transciever).[/size]
For critical listening I'm using analog input of Conductor conneted to PS Audio PWD MKII with bridge card.
All audio devices are connected to PS Audio Powerplant P5 with Multiwave regeneration enabled.
Burson Conductor is really great product.
I'm interested in the difference the fuse makes also. Debating on whether to replace fuses in my power amps too.
Guys sorry for the delay, I have already replied to Dan via PM, but this may possibly help also to others so i'm pasting it here for the reference:
Yes, the supreme fuse made the difference - the sound got a bit more colour in mids, bass impact improved with my HD800 headphones and the music sounds better connected together.
But to be honest the most analytical testing with Supreme fuses I did with my previous Burson product - HA-160 and for the new Conductor I replaced the fuse on second day the Conductor was delivered to me, so did not compare too much as for me the Supreme fuse was clear way to go after the experience with HA-160
BTW with HA-160 I got improved dynamics after replacing stock power cable with shielded Supra Lo-Rad cable (not really expensive cable) - this also improved "blackness" as I think I had quite a lot of noise coming from other power cables and switching power supplies from other devices nearby. Again i'm using the Supra power cable from the moment the Conductor was delivered so can't comment if exactly the same applies also for Conductor, but I would believe so..
Hope this help a bit.
P.S. Make sure to test putting Supreme fuse in both directions and stay with the one you like more. Somehow there is a difference in which way the fuse is inserted (you will easily notice it in amount and control of bass). Also i recommend using contact cleaner before applying the fuse and not touching the contacts with bare fingers.
