BGVP discussion thread DM7/ DM6/DMG and NEW BA series
Jan 21, 2019 at 3:24 AM Post #1,741 of 5,353
The es100 does look really good. But is it really using microUSB? Maybe if they release an updated one with USB C, I'll grab it—petty, I know, but my laptop/switch/portable hdd/phone/battery pack are all USB C; I'm not going to buy anything using another type of connection at this point.
Other than that, it seems like a good deal—it's not really much more expensive than various MMCX wireless solutions, and has more than sufficient specs to crush all of them. Everything else really does look great.
unfortunately it is still using microusb, been using it with balanced with the DM6, with ldac, it sounds really good
Jan 21, 2019 at 3:26 AM Post #1,742 of 5,353
This photo is for reference to show cable. The next cable I get for the DM6 will be the Han Sound Audio Zen 4 wire OCC litz copper cable terminated Furutech 4.4mm. This cable in the photo is two pin so I can't use it with the DM6, but the cable is quality and has a great sound with BA IEMs.
Here: $168
https://music-sanctuary.com/products/han-sound-audio-zen-4-wire-occ-litz-copper-cable
qdc Anole V3 IEM #817993 (stock setting/Sony Hybrid Tips)(Han Sound Audio Zen 4 wire OCC litz copper cable terminated Furutech 4.4mm)
Sony NW-WM1A Digital Audio Player (Japanese Tourist Edition) FW 2.0
Damn that's just a sexy combo.
Now I wanna trade in the clear DM6 for the black. The ALO Audio OCC copper cable and its black jacket would look pretty nice here too.
Either way, that cable is gangster.
Will have my WM1A next month :wink:
Oops just looked closer, that's not the DM6 :frowning2:
Jan 21, 2019 at 3:44 AM Post #1,743 of 5,353
I’m planning to order a 2.5mm balanced OCC cable for the DM6.
Can anyone recommend a straight/right angle 2.5mm balanced to 3.5mm standard adapter ?
AliExpress has a few but not sure if they are any good.
I don’t have a balanced output device as yet so this way I can adapt the cable for both purposes.
@Dsnuts maybe you know of one ?
Jan 21, 2019 at 4:41 AM Post #1,745 of 5,353
Just received the nicehck 16 core copper cable. The balanced version. It's really well made, very flexible, looks nice and is more comfortable without the pre-formed earhooks.
If only i had my dm6's allready... Won't be here till march. Using the cable on magaosi k5 (the nicehck version) atm. No huge difference.
Jan 21, 2019 at 4:51 AM Post #1,746 of 5,353
The one from Fidue is great https://www.aliexpress.com/item/Fidue-2-5mm-Balanced-Adapter-for-Stereo-HIFI-Player/32821705265.html
Fiio also has a good adapter https://www.aliexpress.com/item/FiiO-L26-3-5mm-to-2-5mm-Audio-Adapter-cable/32769832885.html
Jan 21, 2019 at 4:58 AM Post #1,747 of 5,353
I bought this from a REC from someone here. Can't remember who, but Thanks! Anyways, It's a bit heavy but sounds and works great!!!
https://www.aliexpress.com/item/OKC...le-Jack-Audio-Stereo-Adapter/32865122372.html
Jan 21, 2019 at 10:57 AM Post #1,748 of 5,353
I'm using this one from fiio, it is the cheapest option I can find, plus it's Amazon prime so if it's defective you can return. https://www.amazon.com/gp/product/B01N10RBPW/ref=ppx_yo_dt_b_asin_title_o04__o00_s00?ie=UTF8&psc=1
I'm also using ES100 and can confirm that it sounds great with DM6.
Jan 21, 2019 at 11:03 AM Post #1,749 of 5,353
Thanks for your input guys on 3.5mm to 2.5mm balanced.
I’m leaning towards right angle or straight plug adapter for increased robustness and to minimise any impact from cable differences.
What @cobrabucket suggested might be it.
Jan 21, 2019 at 12:23 PM Post #1,750 of 5,353
Jan 21, 2019 at 2:20 PM Post #1,751 of 5,353
Jan 21, 2019 at 3:00 PM Post #1,753 of 5,353
Hi,
Any solution to prevent dirt from getting inside the earphones from the holes?
I noticed a big difference when changing the tips. Could you please recommend good tips for DM6?
Thank you
Jan 21, 2019 at 3:02 PM Post #1,754 of 5,353
Hi,
Thank you
Try kz star tips. Cheap and perfect for the DM6
