Beyerdynamic DT-1770: Product Info, Discussion and Impressions
Sep 16, 2015 at 5:44 AM Post #438 of 3,712
  This HP is successor of dt770 by name, but not in price :/ 3x higher. Supposly its entry gear?
It's a continuation of it's legacy and at the same time bringing up the high-tech and sound quality a few notches. Hence a higher price.
Sep 16, 2015 at 2:05 PM Post #441 of 3,712
I only had the T70p for a short time long ago. So I cannot comment on all the cans that you request, but this could be Beyer's HD650.
Sep 16, 2015 at 2:07 PM Post #442 of 3,712
Btw, I switched to the Leatherette pads. What a fulminant  bass......
Sep 16, 2015 at 4:20 PM Post #444 of 3,712
It is not too heavy to me, the weight is well distributed by the very comfortable headband. They clamp with just the force that is needed to secure them on your head. My Sony MDR-Z7 is more comfortable though. But not by a big margin. This is a PRO model. You will wear it proud and always know that it is safe on your head, never be afraid that it will fall off. And it is built like a tank, can take some heavy punishment for sure.
Sep 16, 2015 at 4:34 PM Post #445 of 3,712
Interesting... We have tried most of the same headphones so, I'm more curious now. Thanks... Or maybe I shouldn't thank you!
Gelocks, I am afraid you must have this headphone. Would be interesting to hear about how you like it compared to the Sig Dj. I sold the Signatures because my ears got to big (getting close to 60)  for the relative small ear cups that Ultrasone constructed. The ED 12 was a treble peaky nightmare for me but the fit was much better than the Sigs. The Beyer standard fits my ears much better. And I think the DT 1770 is bass head material.
Sep 16, 2015 at 5:59 PM Post #446 of 3,712
You may have just sold me on this.................
Sep 16, 2015 at 9:43 PM Post #448 of 3,712
Out...
Sep 16, 2015 at 11:09 PM Post #449 of 3,712
  ... And I think the DT 1770 is bass head material.
@RERO, @Syntax
I noticed perceptible difference between velour pads and pleather pads on DT1770.
Specifically, bass amount and punch increase on pleather, treble amount increases on velour.
I wrote DT1770 is not an upgrade of DT770 but DT150 on some post, but now I have to revise my opinion.
That is:
--DT1770 with velour pads is similar to DT770 in tonal balance
--DT1770 with pleather pads is similar to DT150 in tonal balance
or:
If you like relatively flat sound or dislike too much bass - use velour
If you like relatively base heavy sound - use pleather
IMO, I think a bit of pad rolling (with provided or even aftermarket ones) would be able to get the bass to where you like it, or even tube rolling or EQ'ing. Even with the price of this thing, I think this 'can is special enough to justify the customization.
Sep 17, 2015 at 12:36 AM Post #450 of 3,712
Out...
IN
