Beyerdynamic DT-1770: Product Info, Discussion and Impressions
Nov 18, 2020 at 8:06 AM Post #3,423 of 3,701
Do you remove pads before fitting the foam discs?
Yes. And, removing the pads is easy, snap off the outer plastic ring WITH the pads attached, instead of peeling off the pads from the ring. Saves you a ton of frustration and time.
When you buy replacement pads from Beyer, they actually comes attached with this ring.
Nov 19, 2020 at 5:55 AM Post #3,424 of 3,701
Thank you. I removed the rings. Do i replace the already fitted foam disc or add this additional disc ontop of it?
Nov 19, 2020 at 8:16 AM Post #3,425 of 3,701
Replace it, I'm sure
Nov 19, 2020 at 12:24 PM Post #3,426 of 3,701
Yes replace it
Nov 28, 2020 at 5:51 PM Post #3,431 of 3,701
Hi, is anyone using the DT1770 pro with the Astell&Kern SR 15 or 25?
Jan 10, 2021 at 6:34 AM Post #3,434 of 3,701
How would you compare this headphone to the Denon D2000 on the technical side: resolution, detail retrieval, dynamics...
Jan 11, 2021 at 10:36 AM Post #3,435 of 3,701
I'm curious about a sundara/dt 1770 side by side. As a closed back, I haven't found a better sounding option, but they are big and heavy. Sundays sound really good but have a narrower stage and less subbass compared to Phantoms. My gripe with the 1770s was always that the bass was unrosolving. Present, but not well defined. In direct comparison, the dekoni blue sound better. Those have fantastic bass. Best I've heard I think. But man are they ugly. I'd love to throw those drivers in my m100s shell. That would be a legit closed back.
