Feb 21, 2019 at 8:58 PM Post #466 of 3,999
Hey guys,
I'm looking for some new recommendations. I've got symbios, Spinfits, spiraldots, final audio...essentially almost all the good ones. Any other recommendations?
How would you compare your Final Audio E Series (I'm presuming) to the Symbios W, Spinfit C145, or JVC Spiral Dots? I'm interested in the Final Audio E Series but it's tough to find a US based supplier or any that ship here.
On that note, if anyone has large, XL or LL tips they don't want and would like to trade, send me a PM, I have am assortment and will not use the small or medium. Thanks.
Feb 22, 2019 at 8:00 AM Post #467 of 3,999
Hey guys,
The KZ "Starlines".
Feb 23, 2019 at 3:43 AM Post #469 of 3,999
https://www.mtmtaudio.com/products/final-e-type-eartips-for-earphone
Mar 13, 2019 at 4:59 PM Post #475 of 3,999
Just to throw in my two cents, unless you have some other tips in mind and know the exact size you want, it's better to just spend a bit more and get the Final E1000. Amazing budget IEMs and all five sizes of Final E tips are included. The fit on the Final E tips is rather finnicky in my experience, as the tips are taller and narrower than most other stuff, so it's safer to get all the tip sizes to try on your IEMs, rather than risking just one size working out.
Mar 15, 2019 at 8:07 PM Post #478 of 3,999
For future reference, the aliexpress foam tips bore sizes.
Listed to fit:
3.0+ mm = T100
4.5+ mm = T200
4.0+ mm = T300
4.9+ mm = T400/500
Actual bore size:
2.7mm = T100
4.3mm = T200
3.6mm = T300
4.7mm = T400/500
Left to right: T100, T200, T300 & T400/500.
