DynamicEars
- Jan 5, 2019
Forgot to ask: What size do you recommend for both tips? Or does it work with all sizes, as long as they're both the same size.
around same size or slightly smaller foam size, I use ML size spiral dots and put in M size memory foam inside. too big inner foam can cause discomfort, feels like too much pressure from inside the eartips
