dannyd123
- Apr 8, 2012
denon ah d2000?
buy an E11 if you want super extra bass. and combine it with beats studio or xb500 or xb700!
if youre into multiple amping, which is definitely not recommended by the way, buy 3 E11 then pair it with your headphones! make sure to turn the bass switch to max
UNDER 400$ NOT 300$
I HAVE 400$
USE FOR LAP TOP ONLY & FiioE11 OR E9
WICH ONE IS THE BEST WITH XSTRA MOR BASS
BEATS PRO - BEATS STUDIO - XB700 - XB1000
all the phones you listed do not require amp. I think people recommanded fiio because it has
bass boost feature but it can be done using EQ anyway.
If I were you I will not waist my time here and just get the XB1000. Like I said, you do not
listen to the music only with bass. Bass makes music alive when the other frequencies are well supported.
This is achieved with XB1000 with its huge driver. Even if you want more bass, XB1000 will be capable of
extra bass using EQ, (more than the other cans you listed.)
XB700 will have more bass quantity than the 1000. But it does not mean your hiphop rap music will sound better.
Any Sony product with 1000 in the model number is better than good.
hmmmm
and again
hmmmmmm
lats time
hmmmmmmmmm
i know with bass i need good sound to hear good song in rap
and other things ,, i'm from middle east ((OMAN)) so the wather not hot only
but its VERY VERY VERY VERY HOOTTTTTTT !! LIKE PIZZA HOT
and i use it in my room not in street with laptop
but its xb1000 good for hot country>? ..
but xb1000 batter then dre beats pro?? in bass in boomy bass and sound?
Beats pro is by far the top beats product. If I have to buy a beats product, it is probably the only phone
I will consider to buy. But it will not happen because there are many other 'better' options to choose in similar
price range. If your focus is more on the design and showing off to the others with your 'beats' headphone, than
you make the choice.
Back to sounds, yes XB1000 can be one of the best choice for hiphop/rap music with impressive bass focus.
Even if you can spend more money, I cannot guarantee there is another headphone that will out perform the
Xb1000 for that genre.
XB line-up has a very soft leather pad that cover your ears. It does heat up your ears over time but
it is one of the most comfortable headphones to wear. So you can choose to wear comparably uncomfortable headphone and
rest your ears from pain every few hours, or warm headphone and rest your ears from sweat every few hours.
thanx alot ,,
so you say sony xb batter then beats pro or studio in bass and good sound
and for most bass xb700.. and bass with nice sound its xb1000
ok
Beats is the least demanding option
XB700 will have more mid bass - maybe you want this since its 'in your face' type of bass
XB1000 will have more sub bass - bass that goes really deep that you can hear a lot. It is not as punchy as 700 but quality bass.
Some claim XB500 have even more bass than 700 but that I am unsure.
ya i see this video
http://www.youtube.com/watch?v=FYmy0rL1ls0
he say this is not boooomy
I WANT BEST HEADPHONE FOR BOOMY BASS AND BEST BASS IN WORLD
You should pm him & ask. he's one of the active member in this forum.
man ,, no one in this forum can help me
I WANT BEST BOOMY BASS HEADPHONE UNDER 400$
SO THERE IS NO HEADPHONE BATTER THEN BEATS IN BOOMY BASS ??
