tuxx
- Aug 19, 2016
Thank you.
Buying Stellio!
Buying Stellio!
@tuxx - Sorry for the late response. As far as I can remember (long ago), I downloaded JetAudio and then uninstalled same day.That's the thing for me, man. If it feels even a little bit buggy or gives you notifications you do not need, I'm not keeping it. The main purpose of having a player in a smartphone is convenience. If it gives you headaches, uninstall, then try something else (like Stellio, of course). Best of luck!
Jet Audio is my go to music app on my fiio x5ii, simply love it and all the possibilities it provides.jet audio and power amp are the 2 apps I recommend for android. I use them with my note 2 and sony Z.
Any app that does music AND audiobook support? Failing that any with a bookmark option?
Thanks
Just checked it again, still does not support full replaygain implementation (track/album modes, don’t know which mode it implements by default but I guess track).Jet Audio is my go to music app on my fiio x5ii, simply love it and all the possibilities it provides.
Hey, after using UAPP with the Meizu dongle for a couple of months, I tried android driver with the AINUR NARSIL mod, and i've found the sound to more open and natural, just like you said. I am using "vinyl music player" from f-droid which I believe is a pretty basic music player that uses the standard android libraries from android 10.I find UAPP USB dac driver is worse than Android driver. USB dac has narrower soundstage. Volume is too loud and the melody/beat is too forward. It sounds too in your face. Android sounds better, even though there's resample. Everything blends in and nothing is too forward. Music is more relaxing and emotional. Is it just me that hear this?
