GN3RAL KARL
- Feb 3, 2009
Im sorry. Are you asking about the PRo700Mk2? The newer Pro500MK2s? Or my Philips earbud suggestion? Sorry to jack your thread there Karl. Will get back on topic shortly.
@RPGwizard ,They don't have the Philips SHE3580 but they have a newer updated version but cost a bit more. Try looking up the SHE3680.. Same phones a bit better build and comes with a case something the SHE3580 is missing. These are the newer versions. Ok here we go.. Instead of the SHE3560. Get the SHE9700 instead.
These are upgrades to the SHE3580. These are longer but not bigger. These use the same drivers as the SHE3580/3680 but because of their housing design the sound has more depth and is better defined on both ends over the SHE3580/SHE3680..These have even a bigger bass punch and tonality in the sub bass is unbelievable in these. I should have shown you guys these instead but for the guys in the States the SHE3580 is cheap and is outstanding in it's own right.
It's all good I might be needing a more comfortable closed-back that sounds good on everything (games and movies), but doesn't leak much sound and gets fantastically loud. I might be checking out the DT660's - I hear they're bass-light but I can EQ it. I checked out those Philips, they seem nice, though some reports of them failing/static in the sound.
I do like those A900x's you got, but am still curious as to how much they leak sound.
