n/a
Would be grateful if Audio Technica offered 5-8 foot cable length exactly like OEM shorter one's. Will gladly pay Audio Technica for one. MSR7b is too good to be used mostly as portable headphone. Considering the thinner plastic parts, suspect MSR7b will last longer if used gently around the home and not hauled around for portable use. Now hunting for longer cable to use with MSR7b at home. Single-ended cable good for me. Don't need the balanced cable.
OEM cables (or aftermarket cables resembling them) all I require - thin, light, plain black coated cables with standard jack/connectors works for me. Nothing happening on Alibaba, Amazon or ebay.
Cheapest option for single ended would be to just use a quality headphone extension cable combined with the stock single ended headphone cable. There are plentiful options in that regard. If you don't want to use an extension cable for some reason, I'd recommend looking at aftermarket options (A2DC is a standard connector type, and while there aren't many A2DC aftermarket cables marketed specifically for the MSR7b, I think most A2DC cables will work - I can say personally that cables marketed for the ATH-SR9 work for instance). The only longer (3m, 9.8 ft) first-party cable I'm aware of is the AT-B1XA, which is terminated as a Neutrik XLR4 balanced connector, and retails for $349:
https://www.audio-technica.com/cms/accessories/c3a7d43af0ab0267/index.html
True there don't seem to be longer length options listed on AliExpress or eBay, but Amazon has some options.
$29 NewFantasia Replacement Audio Upgrade Cable Compatible with Audio-Technica ATH-MSR7b, ATH-SR9, ATH-ESW990H, ATH-ES770H, ATH-ADX5000, ATH-AP2000Ti On-Ear and Over-Ear Headphones 2meters/6.6feet
https://www.amazon.com/NewFantasia-...hnica-ATH-ESW990H-ATH-AP2000Ti/dp/B07V1QJKMQ/
$31 NewFantasia Replacement Audio Upgrade Cable Compatible with Audio-Technica ATH-MSR7b, ATH-SR9, ATH-ESW990H, ATH-ES770H, ATH-ADX5000, ATH-AP2000Ti Headphones 3meters/9.9feet
https://www.amazon.com/NewFantasia-...hnica-ATH-ESW990H-ATH-AP2000Ti/dp/B07V3BFPTL/
And for those looking for a longer 2.5mm TRRS balanced cable, there is this 2m (6.6ft) silver plated option:
$52 NewFantasia 2.5mm Trrs Male Balanced Cable Compatible with Audio-Technica ATH-MSR7b, ATH-SR9, ATH-ESW990H, ATH-ES770H, ATH-AP2000Ti Headphones and for Astell&Kern AK240 AK380 onkyo AK320 DP-X1 FIIO
https://www.amazon.com/NewFantasia-Compatible-Audio-Technica-ATH-ESW990H-ATH-AP2000Ti/dp/B07VK46J77/
Yes saw those when searching. Have used NewFantasia cables in past. From three purchased for noise cancelling headphones, two developed shorts in under six months, so reticent to try NewFantasia again. Price is acceptable though. Perhaps flip a coin? Heads - extension cable, Tails - NewFantasia.
Speak to Matt at Forza Audio Works. He seems to be able to access most connectors and has a wide range of excellent quality cable materials. I have used him for a couple of different headphones and am currently waiting to hear back from him about a set with a 2.5mm balanced plug as I don't have anything with 4.4mm.
Stay updated on Forza AudioWorks at their sponsor profile on Head-Fi.
Calming the treble down is relatively easy and doesn't need EQ. You can try using a piece of felt or foam between the driver and your ear. Just cut an oval the shape and size of the pad and stuff it below the cushion. For these AT headphones it works wonders and doesn't mess with the sound too much.Update to previous post. Purchased and using New Fantasia cable for MSR7b. Wanted more length as OEM cable very short even for desktop. Hopefully no issues as previous New Fantasia purchases. Using H2 with MSR7b. x10 cost difference, though these cans can scale OK. MSR7b as others have stated, can be strident in treble. Tried minimal EQ to address, but heard some negative results in other regions of sound, so back to factory EQ. On most my recordings not bothersome, with caveat I'm older guy with older guy hearing losses which may make sometimes hot treble on some tracks less annoying than for younger listeners. Have leather ear pads (leather most surfaces, protein leather where pad attaches to headphone cups) purchased but not used for my old MSR7. Learned from experience with headphones how easy it is to mess things up when swapping stock pads for aftermarket pads. Mostly content (and my checking account too) for having moved from expensive bulky headphones to budget MSR7b's.
