- Jun 7, 2007
Yes, updated, different drivers than the esw9.
Eddie C.,
That's an awesome mod. A couple of questions:
- Did you have to do any drilling of the outer frame or wooden housing to fit the mmcx connectors?
- Can this setup now accommodate off-the-shelf cables using mmcx male connectors, such as those designed for Shure IEMs?
Thanks!! Im glad you enjoy the mod.
-No drilling, prior to the mod i measured the hole and the mmcx connector with a digital caliper and the hole on the frame is just slightly larger. I heatshrinked the mmcx connectors which are clamped by the wooden plates so no glue required and wont scratch up the wood.
-Definitely!! I just used them today with the black ue900 cable, works perfectly
Great. I'm thinking I'll do this mod on one of my ESW9's when I get some free time.
will any mmcx connector work? or is there a particular brand that is slightly smaller than others?
Im sure other styles will work, But this is the style of connector I have used and it fit perfectly after a layer of heatshrink, did not require glue to hold it in place
Many thanks, Ordered the parts so i'll be modding my ESW9 soon
