tim3320070
Well how would I know that, it didn't sound that way to me when written out....
Originally Posted by IPodPJ /img/forum/go_quote.gif How is the Ref1 compared to your PWD? |
Originally Posted by soundlogic /img/forum/go_quote.gif 1. I am not in a hurry to do comparisons on equipment that is essentially "fresh" with only a few hours on it compared to something well broken in. It dismays me greatly to read enthusiastic...almost giddy...comments on this thread, regarding how GREAT a component/and or cable combination is, only to have them retracted/changed after sufficient serious listening has occurred. Sound familiar? 2. Any comparisons would be noted in a separate thread, rather than to listen to the "off topic" whiners. |
Originally Posted by tim3320070 /img/forum/go_quote.gif I asked Kingwa about the CD7 last night and he said that has been discontinued and a new transport is in the works with a dual chassis like the Phoenix. That's all I know right now. |
Originally Posted by scootermafia /img/forum/go_quote.gif The Diverter is great with Amarra and the DAC8/Ref1 and Phoenix and HD800. I wrote a review, see my sig. |
Originally Posted by Pricklely Peete /img/forum/go_quote.gif The Illuminati kit makes a noticeable and positive contribution. Best 7 buck tweak I've come across. Try it and see for yourselves guys (those of you willing to solder your fingers and burn the table cloth that is One kit should be enough to rewire the RE1 inputs and the two spots where the digital signal is passed off to the individual DAC/channel boards. Peete. |
Originally Posted by les_garten /img/forum/go_quote.gif How hard was it to work with? |
Originally Posted by Pricklely Peete /img/forum/go_quote.gif Fairly easy but it's very small diameter coax that is a bit fiddly to terminate properly. You have to be careful not to score the drain wire or the foamed Teflon around the center conductor. Once you strip the outer sheath off you peel back the foil shielding to expose the drain wire and center conductor. Other than that it's pretty straight forward. My big mits and large fingers don't exactly help when it comes to tiny cables. For some reason cabling is my biggest challenge with DIY work. I had similar fun trying to get that damned solid core Belden copper crap soldered to those cheap CAST connectors (when I forgot to order shark CAST cables with the Phoenix)....although this job was much easier than that. I'd say the outside diameter of the Illuminati cable is 23awg and it's fairly flexible (easy to shape into a nice arc). The two conductors are 22awg. Peete. |
