Pricklely Peete
Franken modder
- Feb 17, 2008
Too early to tell as I am just still at about two hours of listening. Listening to a high quality recording of John Williams classical music now and no sibilance yet. The poor recording was of live music probably audience recording with two mics versus a soundboard and at 256k. Miles Davis "So What" will be a good test because on good gear it can sounds harsh at times because he was mic-ed too close. Seems like you already got your sources so I would think the Phoenix or what ever Kingwa replaces it with someday is likely in your future.
Your assumption is correct (too early to tell) ......with such fresh electronics it's hard to tell what is recording artifact and burn in process with Kingwa's higher end stuff. The changes the Phoenix will go through as you put more and more hours on it should make themselves known (as long as you use a fav piece every day to evaluate any changes). Some folks report burn in changes while others are more skeptical about such things...Personally I feel A-gd gear (the high end stuff) has a distinct quite noticeable maturation process that usually concludes around the 400 hour mark (300 hours home use since the Factory burns in it's gear for 100 hours before shipment).
Ah is correct the leap from SE'd to balanced using the ACSS pathway should be another big eye opener. Personally I've not noticed the so called 650 veil...I use an aftermarket DIY SPC cable terminated in a 4 pin XLR (the kit A-gd supplies is what I used for the conversion of my SE'd DIY cable to balanced). I observe no veil at all. It might be a case of first gen 650 drivers vs the updated units shipping the last 2+ years and a system oriented observation (using a dark amp/dark dac and the stock copper 650 cable). Just IMO as far as that goes.
Welcome to the club bub
Peete.
