Pricklely Peete
Franken modder
- Feb 17, 2008
As Usual...
Great Googly Moogly!
Lot of work there!
I was wondering how you were going to do those relays on the bottom.
Thanks Les ! Yeah the relay banks are a bit of a head scratcher right now. I don't want to unsolder all of the wires at one end. Maybe you and some other enterprising DIY types could toss out some ideas/suggestions, that would be a great help and appreciated (by myself) for sure.
I have one way in mind already (which is explained below the attached pic).
For now though I'm done with anymore DIY work this evening. I have the amp reassembled and back in the ref system and I'm extremely happy the Phoenix is working as it should once again. I had a tense moment or two after the hitting the power switch.
Kingwa answered my question really quick, god bless the man. He said the likely culprit was one or both of the 470uf 16V caps. I was more than nervous at power up since I wasn't 100% sure it was just the cap or caps in question. I sure am glad it's working once again (to say the least).
Just an FYI to members/lurkers that read this post and the previous one on page 186. This problem only affected the first 10 amps shipped. Any amps made after the initial run of 10 have this problem fixed (with better quality caps).
Here's a pic of one for the relay bank's wiring
Better angle of the solid core jumpers
As you can see +5K G2 and +5V are solid core jumpers while the other 3 connections are made using the stock Audio-gd stranded SPC. Like I said earlier the plan is to unsolder the 3 solid jumpers from the top of the relay pcb and then lift off each pcb assembly until it clears the top of the solid jumpers, then rotate the boards back 180 degrees.
If it comes down to it I will unsolder all connections but I hope that my idea or another members will save some labor and time.
EDIT: It occurs to me that the signal must pass through these wires (or at least some of them). I bet it'd be a good idea to swap out the stock stuff for some better quality wire. I have both Legenberg copper and Mundorf silver/gold hook up leftover ....hmmm. I think I'll change it out and get those last 12 caps swapped at the same time. Might as well even if it makes little difference....who knows though it might make a big difference. I certainly won't know unless I try it. I had low expectations for the RE1 MAX mod but the outcome has proven to be quite substantial. Cumulative small changes are just as effective as singular but significant ones in the end. What the hell ....I have the time and the material needed on hand already
Peete.
