The Monkey
Monkey See, Monkey DAC
A really sick dud
- Oct 28, 2004
That's a great tutorial, Les.
Originally Posted by The Monkey /img/forum/go_quote.gif That's a great tutorial, Les. |
Originally Posted by lmswjm /img/forum/go_quote.gif Peete that is some good stuff! This is one mod that I'm putting on the project list for the future. |
Originally Posted by Pricklely Peete /img/forum/go_quote.gif No idea Les. I'm guessing here but I bet it's a silkscreen error like the one I caught on the ACSS inputs a few pages (and weeks) back when I rewired all of the inputs. They were also flipped but I did not realize it until I powered it up for the initial listening test. The outputs for the preamp (RCA/XLR) were also unique in the fact that they had incomplete screening and had seemingly swapped phase. I bet the explanation makes perfect sense from Kingwa but my skills at dissecting a topology this deeply (and without a schematic) are woefully inadequate. PG I have suggested a number of times in the last year or so that Kingwa look into upgrading his stock wiring choice but I also tempered that suggestion because of the potential impact it would or could have in pricing depending on the choices available. One aspect of customer service A-gd is happy to accommodate is the installation of the wire of your choice as long as you provide the raw materials before the build of your particular piece of gear is started. It's a good compromise I think and it gives your gear a personal touch (one of a kind ) although you may or may not recoup the cost of the wire if you should decide to sell. It should help rather than hinder I would imagine. The C1 masters are in the plans for this year but I need to complete the rebuild of 2 Odyssey Stratos amps first and then sell those to help finance the purchase. The shipping cost alone for a pair of C1's is substantial (around the same cost as an "A" version FUN). I'll be rewiring the FBI-500 integrated amp which is currently waiting (partially disassembled) on a major part to be built at A-gd, then shipped. Luckily the transformers passed all the tests so it looks as though just the L channel output board (mains caps, 12 Toshiba power transistors) bit the dust and nothing else. This amp I hope to modify into a power amp for use with the Phoenix or if the preamp section is just as good as the phoenix (after it's rewired of course) I will use it instead as integrated and bump the Phoenix to the head fi rig. I need to add a set of preamp ACSS outs (to feed the C1 Masters) which should be fairly easy to do. At least it seems like it should be fairly easy to accomplish. As always I had better talk with Kingwa about the veracity of the concept. Peete. |
Originally Posted by haloxt /img/forum/go_quote.gif They should keep some plain copper or silver internal wiring at hand just in case people don't want SPC, lots of people seem not to like the tonality. |
Originally Posted by tim3320070 /img/forum/go_quote.gif The preamp is supposed to be essentially the same as the Phoenix according to Kingwa. |
