I have not confused anything.
All test was done with 96kHz sample rate data, which means they should all be able to reproduce up to 48kHz sound.
But when the data goes from NFB-12's USB receiver, the reproduction is not correct. Other digital interface such as RME's babyface or even Audio-GD's own Digital Interface got 96kHz data to the DAC correctly.
It clear from the FR plot. Both babyface and digital interface to NFB12's DAC reproduced quite flat FR to about 30kHz, then roll off to 48kHz, it's okay since there is LPF(low pass filter) working.
At 48kHz sound, it's about -9dB roll-off, actually, NFB-12's LPF's roll-off is about -6dB, but my recorder card has it's own roll-off too, so I got about -9dB here.
BUT!!!!! From NFB-12's USB receiver, the roll-off (it's actually CUTOFF, but RMAA smoothed it, can't disable it) start around 22kHz, the sound is virtally none from 24kHz onward.
