malaLamicka
- Feb 13, 2012
well, Koss UR/30 definitely no go. No difference between old sony ac receiver and this amp. I will need to look at some HD 600 and above.
It's not that it particularly bothers me. A good sounding amp is a good sounding amp. I don't plan on buying it because the word "warm" scares me away, which is unfortunate because only through listening to it myself could I know if it is too "warm" for my tastes.
The HF cutoff is more a nagging interest than anything else. A curiosity.
We must had the NDA with Tenor company, then we can applied the TE7022.
I don't want againest the law, We can't reveal about the TE7022 built in technology.
You are better send email ask Tenor company direct.
Now that Kingwa has revealed the TE7022's internal circuitry affects the FR and his non disclosure agreement, (NDA?) with Tenor limits his ability to reveal the specifics, I for one feel like we have an answer as to killKli's question. Going forward. I really look forward to members opinions and impressions regarding the newest version with the switches to change the filters easily. I think this upgrade came as a result of our feedback in this forum. I am sure there will once again be complaints regarding frequent upgrades as a "problem". However, I for one think when people suggest improvements, and the company responds, this is a good thing, not a problem. BTW, hopefully someone here can devise some circuitry/switches, perhaps mounted in the top panel, to enable this upgrade in the 2nd gen models that use the jumpers. Kingwa maybe?
It has a fair bit of power, so most headphones will be driven properly on it.
Depending on your budget there are quite a few options available. I personally have tried it with the HD 650, and I can tell that it's a good combination.
I think it would be wiser to ask the same question in the Headphone recommendations thread, they will be sure to point you in the right direction. Do mention a budget, though!
Mind giving some impression about the hd650 + nfb12?
I may be able to borrow a pair of hd600 and 650 in the next month. Kinda wondering if their "syrupy" sound sig will play nice with the nfb12
I know Tilpo thinks it's a good pairing, but I think the NFB12 really doesn't do justice to the HD650. I like the NFB12 as a DAC and it's OK with my DT880/600's, but not really with HD650's. I would use veiled as an adjective for HD650 with the NFB12, but not at all with Bottlehead Crack or Hifiman EF5.
Do you think it's because it's quite a warm dac/amp with a warm headphone?
Thanks. Suspected that might be the case. It actually sounds pretty good to me with the HD600's. Sounded great on the DT880s (250 ohm) when I had them as well. I also tried going RCA out to my PortaTube just to see how it would sound - and that was a really nice combo also.
Have you tried your HD600's or DT880's with an OTL tube amp? I think that'll take both those cans to a different level altogether. My DT880/600's are fine on NFB-12 but much better on the Crack.
