koonyue
- Mar 9, 2011
Kingwa,
We all know fw#4 and driver v1.2 is newly release, and personally I really don't mind if the native VIA ASIO driver can work under 32-bits or not (I switch to Linux recently)
However, since all my previous DAC are working with ASIO 32 bits, it is the only way I can compare your DAC with my previous one, head to head
To:extreme4099
"This is assuming you already have set the sample rate to 32 bit + Whatever sample rate you chose higher than 44.1k in the A-GD usb deck"
Yes, I have choose 32 bits in A-GD usb back (aka Envy control panel), see my post here
http://www.head-fi.org/t/638251/audiogd-dac-with-asio-problem
I have the same conclusion as Warrax, the new VIA ASIO driver can only work under 16bits, as it show in this screenshot posted by Warrax before:
So, I only have ONE question, can Kingwa, or anyone, give me a screenshot like above in Foobar, showing a bitrate beside 16 bits, be it 24 / 32 bits, whatever. Please let me know and share your settings
It is no use for us to try difference settings, or reinstall driver (already did this > 10 times), just post a screenshot to proof the driver is OK (either XP / Win7).
Thanks
To:extreme4099
Thanks
