Saraguie
Have you put the switch on the front to USB, gone into System preferences > sound and switched to line out?
Also open Audio Midi Setup and find Line Out with USB icon, and set up your Output on the left as you would like the Format and Bit rate.
Me personally I have switched to using the headphone out as a digital to toslink for the last week.
I have not A/B except for 10 seconds about 1/2 hour ago coincidentally so take with a grain of salt (I am), I think it sounds better. And I have bought a $90. USB cable. So there is a lesson here, I'll leave to you to interpret.
Hope this helps.
PS: MACs rule
Hi , i have been using my NFB 11.32 under Windows 7 with no problem , now i switched to an iMac cause it was a christmas present , however when i plug the NFB 11.32 via USB nothing happens , it is not recognized. What must i do to make it work in my iMac ? Is someone using it with a Mac ? If someone can help it would be great .
Regards.
Hope this helps.
PS: MACs rule
