/img/forum/go_quote.gif
I'm using the NFB-10ES on my HE-6, there's PLENTY of power.
When people say you need speaker amps for the HE-6, they are kind of right in a way- you need an amp comfortably capable of around 2 watts into 50 ohms for full potential performance of the HE-6's. Some might say 4 watts. OK, I won't quibble over 3 dB.
But I bet if you connected a pair of speakers to the NFB-10 it would drive them just fine at moderately low levels. It could rock your house pretty fair with a pair of Klipschorns!
So, in a sense the NFB-10
IS a speaker amp- it's just not built so that it could actually drive speakers properly. Add a 3x bigger power supply and 5 times the heatsink area plus a little forced air cooling and you'd have a FINE "speaker amp." This is true for all the larger headphone amps. Given a little more beef in the power supply and heatsink departments and they can drive speakers. There are folks who use appropriately modified Beta 22's to drive high-efficiency speakers, for example.
