somestranger26
- Dec 6, 2007
Ugh double post
The AMP section of this thing is based on Roc or RocSA?
I suppose I't the SA version which means I should be "musical" sounding. This could explain the "juicy" sound.
With that treble it doesn't look like a good friend for the HE6.
To the extent that it is based on either (and I'm not saying it is, I have no idea) I doubt it would be based on the ROC SA. As I undertand it, the ROC SA didn't support ACSS, whereas I have been told that internally the communication between the NFB-10 DAC and the amp is via ACSS. This should keep the signal neutral. All of the Audio-Gd ACSS-based gear is neutral-sounding.
Best regards,
Adam
WOW this thing drives the HE-6 well. Screw the naysayers who think you need a speaker amp. Just from plugging it in I can tell a huge improvement in instrument positioning and bass (I was using EF5 from DAC-19MK3before). It's like having a subwoofer on my head. If anyone is wondering about treble, the NFB-10 is very deft about handling it but does not overpower whatsoever. Some songs have a bit too much treble energy but I think I can blame the recording (e.g. Armin Van Buuren's new album, track #13 with BT). Vocals are very... natural, they blend perfectly with the rest of the music. The volume control is really nifty and I'm using it around noon/1 on high gain. Low gain takes pretty much max volume for good volume levels.
Nice I'm glad your liking it and hope it's worth all the trouble/delays you had in acquiring it. Its good to hear it drives the HE-6 well. The HE-6 clearly takes a lot more juice than the LCD-2 - I like listening to the LCD-2's quite loud and around 12 o clock with gain off is usually where I have it. 9 o clock is still very listenable though. Are you running the HE-6 balanced?
One thing I'd be really interested in is how big of a difference the digital interface and BJC BNC makes in your setup versus just using the NFB10 straight from the computer in USB mode like I do. But burn her in first mate
