goobicii
- Feb 21, 2013
What is different between M8 and M9?
i think the shipping page only shows direct buyer, those who make purchase via dealer will not be on the list. I bought few pieces of agd via a dealer last time with direct ship from audio-gd warehouse and my name was not on the list
anw, can you please tell me a bit more about the amp part of m11? is it quite far from m9? as im planning to buy the m9 but the attractive price of m11 really bothers me T_T
Thanks
I think this is the 1 million dollar question. How good is the amp of Master 11 compared to Master 9? In the same manner, how good is the DAC of M11 compared to Master 7?
isnt the dac only 4 chips total like DAC19?
I thought DAC-19 has 2nos. PCM1704UK only? Where was it mentioned 4?
ops sorry, was thinking about the sa1.32 dac, uses 4 chips but in different config and single end only, sound is also much different from master7 tune
thanks for correcting
Comes down to single ended or balanced. The DAC19/C2 is the M11 single ended in two cases. Both have advantages depending on what's important to you though that might make the extra money for the M11 worthwhile even for single ended use.
Dac19 (10th anniversary) has two pcm1704uk's
M11 has four pcm1704uks's
Actually they both have one 1704 per channel, the same power supply per channel, and the same analog section per channel. What the M11 does is double up for the balanced side and can use a smaller transformer for the DAC portion since it doesn't need to power the analog side as well. It's explained in the Summarize section of the three products. Audio-GD is kind enough to include circuit diagrams. Ignore them at your own peril. I believe you had the 28 and not the C2 though which are different amps which might count for the difference when used single ended.
Top be clear, if you are going to run balanced... buy the M11. Single ended the M11 still has some advantages and disadvantages to the DAC19/C2 combo and people should make their choice based on budget, real estate available and whether the functional differences are worth it to them. I only use IEMs now and the rest of the time studio monitors so for me the M11's slower curve benefits the IEMs and the balanced out can feed the monitors. So for me it's a win win.
Having owned the dac19, and recently selling it.
The m11 is not like the dac19.
I thought I would get a minor change in sound quality. It was fairly notable in fact. The sound stage was significantly more opened up and details were also notably improved.
The dac19 was awesome, don't get me wrong. But I wouldn't say It's that close. Buying the m11 will assume you will be using it in balanced mode to receive the full benefit.
The dac19 is great for SE. But the m11 is a notable improvement when using Balanced.
Having owned the two, that's my opinion.
Applies ACSS technology, even though maybe you only connect to XLR or RCA output, Master 11 will always operate in ACSS technology, and benefit from ACSS technology. Therefore, XLR and RCA output will also definitely bring about improvement in sound quality. Even through RCA output, the 4X PCM1704UK DA chips will perform fully.
