- Jul 12, 2007
Idle 60-70us
With DI-DSP 700-800us (ASIO)
Win 7 64bit
Win 7 64bit
guys, please check one thing - do you get BSODs when you use upsampling via jumpers on DI?
i have just found out that my DI doesn't actually play 96khz files without being set to upsample.
96khz file + no upsample jumpers = scratches and noise instead of music
the same 96khz file + 96khz jumpers = music
Ok, so i've had my DI-DSP for about a week now. I burned it in on my server and have just moved it to my main rig along with my W4S DAC1.
I cannot get 192k to work for the life of me. everything else works, even 172. I have tried multiple software (Foobar2000 and Jriver) and every possible output settings (ASIO, WASAPI, Kernal Streaming) and still no luck. Even from the windows sound setting 192 does not work, the DAC just does not detect it. I have confirmed from W4S that the DAC1 does support 192 over COAX. so i still have no clue what is causing this problem. its not a deal breaker for me, and i am completly happy with the DI otherwise, but one of the reasons i bought it was for the 192 capability! argh... hopefully updated drivers fix this.
