scarfacegt
- Nov 4, 2010
So reading the last pages, it looks like its not worth the risk updating the mobius?
At least not on the same computer that bricked your last one.After having bricked my Mobius I have just received a brand new one from the retailer where I originally purchased it.
It's obviously an old model they had in their stock as it didn't come with the microphone pop filter when my first one did (grrr...I should have kept it instead of sending it back with everything). Being "old" it also has a very old firmware:
USB 99
MCU 1.30
DSP 23
I would love to update it to the latest version but based on my previous experience I'm really scared to try again
Hi,
How I can make Mobius work on Smart TV? I like to run 7.1
The only solution that I could imagine is using any kind of computer to:thank you a lot, I will buy a simple sound card and try. I will share my experiment
At least not on the same computer that bricked you last one.
Just tried the update and get the DFU driver error.... ???
To disable driver signature enforcement do the following:
- Press and hold the Shift key on your keyboard and click the Restart button.
- Choose Troubleshoot > Advanced options > Startup Settings and click the Restart button.
- When your computer restarts you’ll see a list of options. Press F7 on your keyboard to select Disable driver signature enforcement.
You shouldn't have to go through all that trouble. Just click on more options at the bottom of the box that tells you driver isn't signed. It will give you the option to still install it if you trust the software.
Follow up:Don't know if this was reported or not, but for some reasons, after updating my firmware about a week later my sound is much quieter when using the USB C-USB A cable with my laptop.
Previously, I would be more than satisfied with about 20-30% of the volume but now it requires me to crank it up all the way to 100% and I don't know if I'm being delusional, but the sound itself is slightly different. Maybe a little bit muffled and has a weird reverb effect, but I may be lying to myself. And all of this with the Default/Flat mode enabled and 3D Audio DISABLED. Also, 7.1 audio channel.
Anyway. Does anyone else experience this and how can I possibly fix it?
Audeze HQ App: 1.2.1
USB FW: 102
MCU FW: 1.71
DSP FW: 25
Please contact support. We typically respond here if we think an issue is wide spread. We have not seen this behavior and it would be better handled through support.Follow up:
The issue seems to exist in 7.1 and 3D turned ON too.
What I found as a temporary fix is to use the Audeze HQ app and switch back and forth between the settings in the Modes tab. Still, I'd like Audeze to fix this issue but they have not spoken a word. And they usually release firmware after months, so I'm worried that a fix isn't coming soon.
The driver installs ok during the installation process, windows just refuses to run it in an unsigned state. It appears in the device manager with a ! When the mobius is plugged in.
Interesting. I have never ran into that situation and I have done every firmware update
IIRCYou shouldn't have to go through all that trouble. Just click on more options at the bottom of the box that tells you driver isn't signed. It will give you the option to still install it if you trust the software.
