Rabso
Hi,
How I can make Mobius work on Smart TV? I like to run 7.1
Hi,
The Surround signal is sent from the software driver when connected to a PC, thus you can only get Stereo from any other source such as TV or games console. You could connect the headphone via Bluetooth or headphones socket from the TV if you have these available.
I've just tried to do the firmware update following the instructions on https://audeze.zendesk.com/hc/en-us...-Mobius-firmware-using-the-HQ-App-for-Windows and something went wrong
I got a message saying it failed to update at the very beginning of the process and now my Mobius doesn't power on at all. Before the update attempt I was running on:
USB 1.02
MCU 1.55
DSP 23
Anyone has a suggestion on what I could try next or is this a perfect case of bricked headphones and all I can do is get in touch with Audeze Support?
I could never get Mobius to work with wasapi in foobar myself.@Audeze
Really need help here.
So, plugging out and in the USB cable doe as well as switching modes ( 7.1, stereo and hi-res ) does get detected by 'Hardware Manager', but not by Windows sound configuration.
Right now I HAVE to have the mode stuck to Hi-Res or I have no sound at all. Last I switched was listening to Foobar200 with the Wasapi (shared) driver.
Foobar locks up whenever I try and play a song right now, as well.
Please help, how can I re-set these settings?
A bluetooth transmitter might work as well.ok while thinking I got an idea that I need your feedback about it. My TV will output SPDIF, so I buy a sound card that read SPDIF then from computer I re-transmit the audio via USB. will this work in 7.1?
The SPDIF would send an encoded Dolby Digital or DTS signal for 5.1 surround to your laptop. You would need some kind of software that would decode this on the fly to turn it back into audio.
good to know. then I will try to search if such software is existing
Update: I found this devices
https://hifimediy.com/UX1-dac
will it work directly to Mobius or I still need computer and software to decode
this may be an option
https://www.vb-audio.com/Voicemeeter/
What firmware version does HQ app show? Please make sure you have downloaded the latest version of the app. Please contact support.New developement with my Mobius.
So err, after the flaking, the cushion deforming and the cracking of the yoke which rendered my previous Mobius unusable, I succesfully RMA'd the headset for a new one.
Alas, now it ( or windows! ) refuses to let me switch modes. Using Win10
So here goes:
- Restarted both Pc and headset several times.
- Updates the HQ app and firmware to the very lastest.
- This morning I used High Res mode.
- This evening it changes it out, yet windows won't follow up on it.
- Windows Hardware manager DOES see the change, yet no sound except in High Res mode.
- The input of Fooba2000 is stuck on High Res as well. I believe so is FireFox.
Halp?
