hawkwindx
- Mar 2, 2017
Yes that is the cable i just got from them. I also really want try the new headband too.Povell42, I have what I think is the latest version of the LCD-3. Here’s a picture of it. Is this what the 1/4 in “newer” cable looks like that Audeze sent to you?
It is quite expensive, yet there are even more expensive ones. It's hard to know when you are getting quality versus just getting duped. If you are gonna take care of it and plan to keep the headphones for years to come i recommend looking into cables.Nice. Did you pay almost $400 for that cable! Yikes! I really would need to hear one before buying one at that price.
Anyone know a good source to buy raw cable so i could build/solder my own LCD3 cables?
My advice, if you’ve found an ideal combination of headphone/amp/dac for the music you listen to, forget the gear and dive into the music. Unless you’re in the hobby for the gear and want to try out as many different ‘flavours’ of sound and dig into the deepest, darkest corners of each recording, you’ll drive yourself mad (and your partner/spouse/kids/boss) and empty your wallet long before you exhaust your options.My advice, keep looking.
For sure. Headphones >>> amp >> dac > cables and accessories. That said, some headphones just don’t gel with some amps. LCD-3s don’t like OTL tubes for example, but love a good solid state. And if the LCD-3 isn’t transparent enough for you, be ready to spend $4k on analytical headphones like the Utopia if you want to unearth muniscua details and don’t really care for musicality. Nothing wrong with either approach - each of us hears differently and wants different things from this journey.AMP > DAC in changing sound.
UPDATE: I was just thinking that the LCD-3 may not be the best/transparent headphone to really be testing multiple DACs & AMPs differences. So, that probably plays a big factor too. For this purpose... my conclusion is specific to my LCD3. Maybe if I had an HD660s and did the same tests, I may be able to hear a difference.
In my experience the LCD-3 doesn’t like OTL amps like the LD MkIII. If you’re into tubes maybe get a different amp, or better yet a powerful, clean solid state.just bought a 2015 july made LCD3, serial start with 271, coming in a week. i am thinking this is my end game headphone. i sold my beyer T1.2. only audeze i have is the sine lightning and EL-8. so will this LCD 3 be much better than those 2? i know i will find out in a week but can't wait lol. i really like audeze sound. both the sine lightning and el8 are good. EL8 is quite good but i think it lack a little bit bass. the sine lightning is my daily driver in office. significant upgrade from dt1350 which i sold as well and don't miss it. does cost a bit more. upgrade from 200 bucks to 300 bucks is quite significant. i have a little dot mk iii. i think should be powerful enough to drive the lcd3. i have several tubes from the 1962 ones which makes it very very warm sounding and those russian and yugo ones which actually sound like solid state. i was telling people if i don't hear improvement from EL8 then my ear is not good enough.
Can't say as I've never heard that version (I have the 2016F). I'm also treble sensitive and find the LCD-3 has plenty of air and detailed highs without ever being sibilant or harsh. I can listen to mine too loud for my health, and on the Audio-gd R-28 it takes less than 10% power to drive them to deafness-inducing levels. With the new headband they're also among the most comfortable headphones I've ever worn. LCD-3 pads are pure luxury.So the mid 2015 lcd3 doesn't have the 3k or 10k spike I saw someone mentioned a long time ago? I guess I'm sensitive to siblance so don't want that so I can listen louder to get more mid and bass sounds.
I’m very happy with my set up as it is, but that amp looks cool. Nice design. And what does R-2R stand for? Is that an LCD-4?
As you can see it is a bit big, 60 kilos for a DAC.
Haha, this is the truth. This is one of the things I hate about this hobby - one day I'm in love with a component, the next I'm nitpicking it apart thinking it sounded better yesterday, the next day it sounds great again! HAHA.
So, I had an interesting experience with my LCD3 last night. I have only been able to use my XLR cable with them because the 1/4 in plug was cutting out. I reached out to Audeze a couple weeks ago and they sent me a "newer" style 1/4 in cable covered under warranty (*very impressed with Audeze customer support). The cable arrived yesterday, so last night i was able to compare. NOW, I have always thought that cables do not make much difference... BUT... the new cable sounds better to me! It sounds like it is less congested then the xlr. I have always preferred my xlr plug because "the more power, the better" right? This may be a difference between the outputs on my Aune x7s amp... but as of last night, I believe the 1/4in output sounded better. HAHA. Could the cable make that noticeable difference? If so, I really want a new xlr cable from them. And...I better replace all my Amazon Basic cables HAHA.
Also, now having a 1/4 in cable that works, I have been able to listen to the different AMPs with the same DACs i mentioned earlier. I now believe that the AMP makes the difference, because I could hear a difference from the same sources with different amps. Who knows maybe it all in the new cable... haha.
