mmm......I also like the LCD 3 + WA7 combo. Am just waiting for the mailman to deliver the Cardas Clear cable for the Audeze. Perhaps this well make the LCD 3 sound even more awesomer.
Audeze LCD-3 Impressions Thread
- Thread starter MacedonianHero
What does this mean in the LCD-3 specs:
Maximum Power Handling:
https://www.audeze.com/products/headphones/lcd-3
What does the "for 200ms' mean?
15W (for 200ms) |
NinjaHamster
- Nov 8, 2005
For 200 milliseconds. Any longer and the drivers may launch themselves across the room.
Thanks.
hyperism
- Mar 18, 2015
Anyone know how to make the LCD3 more comfortable to wear?
It seems to me LCD2 was more comfortable. Maybe i'm just imagining things.
The planar comfort pad is your best best. A seller over here on this site has them: http://www.head-fi.org/f/6553/cables-speakers-tweaks-accessories-for-sale-trade
Those leather straps? The dude who makes those is pretty cool.
hyperism
- Mar 18, 2015
I think it's the strap that's the issue. It's too thin and the padding is not well made.
I've never had a problem with HD700's construction, but then again the LCD 3 is a heavy monster.
sushster
- Sep 21, 2015
I have a pair of LCD-3's and EL-8's setup through a creative X7 DAC.
I like the sound, but wonder if I should be upgrading my DAC?
tolik212
- Jun 17, 2015
If you like the sound, than probably no need to upgrade. But you can try to visit some audio saloon, and ask if it is possible to bring you phones, and to listen to their gear. Than you'll be able to make a final decision, is it wroth to upgrade.
To me X7 has definitely not the best headphone amplifier. It's ok for hi impedance load, but if you phones below 64 ohm, that amp tend to distort...
I was starting from the buying or building good amp at first.
sushster
- Sep 21, 2015
Thanks!
NzAudezey
- Dec 4, 2013
Head-fi member Lohb makes a great leather suspension strap (I've got one and it makes a MASSIVE difference) also Audeze is launching a new suspension headstrap around 1st nov which from what I have read is a game changer for the LCD series comfort but is a lot more expensive that the leather straps Lohb makes.
- Jan 1, 2014
100% agree. I have the Lohb suspension strap, and it's a great add to my LCD-3F's. I also had the chance to try the new Audeze carbon-fiber suspension strap version - twice actually, once on the Z prototype at RMAF 2014 and just recently at the 2015 RMAF on the LCD-4. Cheers
NzAudezey
- Dec 4, 2013
How did you find the new strap in comparison to the Lohb strap? I'm seriously considering getting one if the impressions I've read are accurate and it is a big step up in the comfort department
- Jan 1, 2014
I like the new strap better. The Lohb strap is a good fix, but it has a few issues IMO. First if you have a big head you have to get a the longer yokes in order to have the headphones fit as the Lohb straps make you lose 3-4 "clicks" on the adjustments. Second the strap causes the headphones to sit a bit precariously on your head, as they're suspended above a bit oddly and the center of gravity is shifted a bit. Not a huge deal, as it is more comfortable on your noggin, but it does feel a bit unbalanced at times.
The new Audeze straps negate both of those issues, and they look Sierra Hotel with the carbon fiber. I'll likely be lining up for a new set (Xmas stocking perhaps?!)
Cheers
Total: 24 (members: 0, guests: 24)
