Just got my new LCD-3, which would be very exciting except that I don't get any audio on the right channel with the stock single-ended cable.
It's the same on four different amps (Gustard H10, Sony UDA1, Schiit Magni 2U, Project Ember II) that all work fine with all my other headphones. If I pull out the plug 1-2mm so that it's not quite fully seated, everything sound fine - I get the correct right channel audio on the right-side driver. So the issue is with the spacing of the ring on the TRS connector.
But it's not just shoddy QC. Both channels work fine with the included 6.3mm to miniplug adapter. I haven't managed to turn up anything with a search other than that the right channel eventually starts to cut out with the stock cable, but this has been a problem for me right out of the box.
Any ideas? The adapter works for now, but it's not really an ideal long-term solution. Should I just ask Audeze for a replacement?
