I posted the following in the "How many times have your LCD3 been returned to Audeze for servicing (RMA)" thread, though I think it is appropriate to post as well in the LCD3 threads as a tale of caution.
Sweetmeat ... I like your idea of a poll ... I assume it was to obtain a better perspective on how bad the LCD3 failure rate is ... or if it being put out of proportion.
For trying to gain some perspective, I commend you.
Though I do find one issue with your poll that if you could kindly update if possible ... the highest choice is 3 times or more ... well, I am on driver failure number 5
in the last 2.5 years of being a LCD-3 owner. The first 4 failures were with the LCD-3C, it was replaced with a LCD-3F which just failed, making a total of 5 failures.
My first LCD-3C experienced 4 driver failures (a mix of left and right) .... so the average ... Audeze Mean Time Between Failure (AMTBF) for drivers is 6.5 months.
Also had a SE cable failure ... which was replaced with a cable which was dead on arrival. So 2 faulty cables.
A total of 6 issues or incidents in 2 years for the LCD-3C.
The wood box is also poor quality ... when I opened my LCD-3 for the very first time , the hinge on the wood box broke.
I should have taken that as an omen of things to come, though I am not counting that as an incident, do not want to appear picky.
I also find the Quality Control of Audeze very poor when performing repairs.
Remember sending it in for a Right Driver failure .... and it came back with a loose Left XLR connector, about 5mm movement away from the Left earcup.
So Audeze fix the Right side of my HP ... and it comes back with damage to the Left side ???
In December 2014 this was replaced with a new LCD-3F (came from my dealer) which just tonight experienced a failed Left Driver ... only 6.5 months old
... so the 6.5 months Audeze Mean Time Between Failure is consistent.
So, tonight, at the 2.5 year mark ... I am on issue number 7, driver failure number 5 for being an LCD-3 owner
The first 4 driver failures were with the LCD-3C ... the latest driver failure is with the LCD-3F ... making a total of of 5 Driver failures while having a LCD-3.
I had hoped that the driver failure issues was mainly for the LCD-3C ... though apparently it is still evident with the LCD-3F.
Had hoped it was a manufacturing issue which was resolved in the first year (or two) ... though newer LCD-3F still experience a high failure rate, which is disgraceful.
I have never had any HP, Speaker, fail .... ever.
DAC's or AMPs ... never.
Some electronics are more than 10 years old and they never fail like Audeze ... actually tonight I had to switch back to AKG-701's that I purchased early 2005 (?).
I treat my gear with respect, listen at low to moderate volumes.
Do not use the LCD-3 for travel.
Used with appropriate sized powered amps ... 1 or 2 Watt.
This is a reference piece of equipment, so it is in my own best interest to treat it with respect, which I do ... still it continually breaks down.
It is not just the disappointment of a product that is so unreliable when it breaks down , it also the continued escalating costs of shipping & insurance for a product which as far as reliability goes is .... shameful.
My average uptime ... that is when I have the LCD-3 at home (when it is not travelling around the world continually being repaired) is just .... 80%.
I think I have a fairly high tolerance and even up to incident number 6 I was still considering getting an Audeze LCD-X as I find the Audeze sound quality simply outstanding.
Also really find Audeze extremely comfortable.
Though, this last incident (number 7), which is driver failure number 5 has me rethinking that thought of buying anymore Audeze (like the LCD-X) very strongly ... I have had enough.
While I do strongly love both the comfort & sound quality of the LCD-3 ...as far as Audeze reliability is concerned, the best word for it is ..... shameful.
I am disgusted.
