MRC001
- Mar 20, 2014
... you no longer get individualized frequency response graphs. I just bought a 2016 LCD 2F and when I called customer support they said they no longer do that as they use a master graph as all units closely resemble it.
In that case, here's the graph for my LCD-2F provided by Audeze. The bumps from 4 - 8 kHz appear to be an artifact of sinusoidal smoothing. The overall shape of the curve is similar to what InnerFidelity measured. You can see how a parametric EQ +3 dB centered at 4500 Hz Q=0.67 would make it nearly perfectly flat Freq Response.
