WayTooCrazy
i am not saying that at all, the balanced cable which is a cheap one i bought off from ebay by an unknown company was really bad. When I replaced it with a good balanced cable the change was really obvious in maintaining sound quality of the lcd2 while pushing it loud with kann. I only have an audeze single ended cable and using it with Kann was not great as compared to balanced. As to volume on some albums I can reach easily 120 - 130, while on other I can listen to music at 100
Again u must know that my previous judgement on driving lcd2 in balanced was from using a very very bad balanced cable and it literally is I think even defective. After replacing it with a balanced cable the lcd2 is driven nicely.
Now what u mean using single ended and an adapter to be used balanced , u can not go from a cable that is single ended and use it balanced by just using an adapter its the other way around, you can go from balanced to single ended
I wouldn't be surprised if the cable you purchased from eBay was wired "out of phase" for one of the channels (or both) which would "suck" the life out of the sound and make it sound Dull and un-lively.
