Sound Eq
- Nov 9, 2013
It drives HD650 ok. I am using SE HO. I have to move the volume to 100/150 with normal amp. I think people will be able to listen to it around 100-103, higher than that is a bit too loud. I just tried 150, it almost damaged my HD650! It is way too loud. The bass is good on Hd650. Not rumbling bass deep but tight and good. With EQ, it does not make much changes on the bass. I think I need more time to play around and compare.
with the eq in ak kann try to boost all low frequencies to +5 and the rest to minus 3 and you will hear a good bass response as I used to do that with my ak380
