Let me have a try try and seeHI @Arion128 have you try DAC to phone? Bcoz i facing noise issues while using it as DAC.
Got mine today place order from Taobao on 17th.
Still testing out.
AP80 - Hidizs next portable Hi-Res music player
Ok, just tried it and seems to be no problem for me. Just using a Samsung Usb c to USB adapter (obtained from inside the box of a Samsung phone) and the usb to usb c connection. Only problem with mine one is that radio does not work from the 2.5mm connector.HI @Arion128 have you try DAC to phone? Bcoz i facing noise issues while using it as DAC.
Still testing out.
maybe I'll try on another phone will it have same issue. Another HK reviewer did mentioned some phone does have this issue.
FYI 2.5MM do not support radio as antenna.
My friend said his one works as I asked my friend to try and he purchased it. straight away after listening.maybe I'll try on another phone will it have same issue. Another HK reviewer did mentioned some phone does have this issue.
tested Both Note10+ have that issue... J7 Prime older phone dont have that issue .
then I need waits my 2.5mm arrives only can test out the 2.5mm works or not...
@Arion128 will they replace or warranty ur AP80PRO Copper edition? Since yours got faulty.
DelicateSoundOfThunder
Hello all, I'm a happy new user of the AP80. It works exactly as I like in a small form factor.
However one point disapointed me, regarding my experience with other player.
When using bluetooth, if the device is disconnected (like car player or headphone), the player don't pause or stop, the music continues.
Did I miss a setting somewhere ?
Thank you.
Thank you.
dimmockg
- Sep 10, 2007
Does the pro suffer from the slight wobble on the volume wheel?
Few comments at FB does mention this issue. Common
Since it is just the radio from the 2.5mm, not really bothered. Have warranty if needed@Arion128 will they replace or warranty ur AP80PRO Copper edition? Since yours got faulty.
It looks yours friend got issue. ours work the correct way. 2.5mm shouldn't support radio as papers write.
OmniscientNihilist
these headphones have a QUAD DAC in them.
4X more dac then the ap80
2X more dac then the ap80 pro
Haha, it looks like that way, thanks for the reply,,, there is a the new Hiby R8..............It looks yours friend got issue. ours work the correct way. 2.5mm shouldn't support radio as papers write.
Hiby R3 Pro Saber . Probably going to change AP80PRO to that... R8 bit out of my range
I've got AP80Pro Copper edition and burning in right now.
It is very cute and powerful and sounds well for its price and size, but I cannot connect Hiby music from iPhone.
Both AP80Pro and iPhone are finding each other, and iPhone even shows it is connected (from AP80Pro, it fails), but cannot find AP80Pro from Hiby music.
I've seen some other guys in 5ch claiming that too.
Any idea I can control AP80Pro from iPhone? Some setting I am missing? Or is it just a bug and all other people having the same issue?
I don't have bluetooth earphones so I can't test that, but I just wanted to try controlling AP80Pro from iPhone (or iPad).
Total: 16 (members: 0, guests: 16)
