hariznordin
- Jan 7, 2010
both phones using 5.1.1No transports do sound different, are you using the same Android version?
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
it's not there.. Kindly adviseTry installing build.prop editor and reading the contents of build.prop (this shouldn't require root). There may be a key under "Unknown" called "af.resampler.quality". Let us know what the value of this key is set to?
Hey anyone know where to find a replacement Micro USB-Micro USB that came with the e18? Just lost mine
Firstly, I am sorry if this is a stupid question and this is the wrong place to ask it (I have searched Google extensively). I was wondering if there is a mini device that would plug into the USB port on my phone and allow me to bypass its volume control and instead adjust it with the device? In other words, instead of the volume being limited to 1-15 steps, I could finetune it with the device. I'm not really concerned about the amp and DAC, as the one in my phone (LG V10) is already very good. If there is such a device, I would like something as small as possible. Thanks in advance for any suggestions.
Then I would suggest that you root your V10, install Xposed framework and then install VolumeSteps+. This lets you have any number of volume steps right on your phone. I set mine to 150 steps.
any dac/amp with a physical volume control, search it up!
