- Nov 11, 2004
Anyone have experience with these new phones and whether they have OTG capability?
Samsung J7 EDIT: Yes
LG K10 EDIT: Not sure
Firstly, I am sorry if this is a stupid question and this is the wrong place to ask it (I have searched Google extensively). I was wondering if there is a mini device that would plug into the USB port on my phone and allow me to bypass its volume control and instead adjust it with the device? In other words, instead of the volume being limited to 1-15 steps, I could finetune it with the device. I'm not really concerned about the amp and DAC, as the one in my phone (LG V10) is already very good. If there is such a device, I would like something as small as possible. Thanks in advance for any suggestions.
Moto E 2nd Gen LTE (XT1524 Surnia) --> USB-OTG cable --> Fiio Q1 - no chance
USB device info just giving info on USB root hub if otg cable inserted. Q1 not even detected with y-cable and extra power supply, regardles of attached before booting or whatever, also tried with USB-OTG-connection via breadboard to be really sure it's not the wiring in between.
Moto E 2nd Gen LTE (XT1524 Surnia) --> USB-OTG cable --> Fiio E17K Alpen 2
strange random drops, rather often
Same for CM13 (AICP ROM) and Motorola XT1524 Stock Android 6.0: direct USB driver of Neutron Player working really bad, switching direct usb access off working better, but not too good - working good for a whole album in FLAC then dropping once (because of touching volume buttons of moto or entering options on Fiio) and subsequently dropping again steadily within seconds or minutes until restarting phone. Actually I checked back on a Sony Z1 Compact with Android 5.1 with some purchased whatever-player and standard Sony-Android-USB-DAC-support and connection was flawless, regardless of using phone volume buttons or entering the options on the Fiio.
Sony Z1 Compact --> USB-OTG cable --> Fiio E17K Alpen 2
flawless
I am very happy with the Moto E that i bought 2 week ago, it work flawless with the Sony PHA3 and Fiio E18, i put around 4 hours a day without any hiccups, I have the VZW model
Is there any way to control the upsampling of USB audio to 192 Khz ?
UAPP: https://play.google.com/store/apps/details?id=com.extreamsd.usbaudioplayerpro&hl=En
Onkyo HF: https://play.google.com/store/apps/details?id=com.onkyo.jp.musicplayer&hl=En
HibyMusic:https://play.google.com/store/apps/details?id=com.hiby.music&hl=En
Neutron:https://play.google.com/store/apps/details?id=com.neutroncode.mp&hl=En
All have USB support. Like the first two. But if your smartphone supports USB DAC thru OTG natively, practically all you can throw at it.
Like my tablet.
Where can I find if my Samsung Galaxy Avant supports USB?
my problem has not resolved.. Help...the only difference I can find is the output for BT is so much better than my previous phone.. HelpI just changed to a new phone..Why the sound quality detiorates??? I thought by using the same dac the sq remains the same.. Help....
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
cool, how would you say the sound compares to the ZX2? TIA!
how to do so?Like I said before, it's likely a software issue. You'll have to request XDA Devs for example to look into what the problem might be.
how to do so?
