TheGadaffiDuck
I know, I have one. So are you not using it as the DAC for your 2blp? It could control the volume for it as well.
I don't even have it yet... Its on its way as i said. Arrives on the 22nd
Okay..... "will you" be using it as the DAC /preamp for the system? My point was that if it is planned to be in your HE-6 setup why do you want a control freak?
With rare exception, everybody giving trial to speaker amps have agreed. These hps act more like a speaker than a headphone.
The XDA has remote volume control, that would be pointless to add another, less is more.Yes i will, and will be using it with my 2B LP and because a big giant Volume Knob Control on your desk sounds pretty. The Micca Origen will be my take with me DAC when i travel to and from Fort McMurray
No doubt but at $2k+, you can find a lot of speaker amps for less.I don't want to discount the WA22 either. The HE-6 sounds almost as good with this amp. A superb pairing in it's own right. There is just that little bit more that the Rogue offers over the WA22.
Has anyone tried the iFi iCAN Pro, outside of the dedicated iFi threads?
Yes. I listened to the iCAN Pro with the HE-6 at length at RMAF last year, it is absolutely phenomenal with them. It really brings out that visceral sense of power that makes the HE-6 so special. I also thought the soundstage was really impressive, when paired with a good DAC.
It's a shame that iFi doesn't know their butt from a hole in the ground when it comes to marketing, because their product really takes the other amps in that price bracket to task, and very few people know about it. Way more people should be talking about this amp.
Good to hear. Which mode did you use? As in SS, tube or tube+. I'm assuming it was balanced output? Also, which gain?
I used the balanced input and high gain. I tried all of the possible mode combinations with the tube and the stereo expander. I liked the hybrid tube+ option best, followed by solid state and then the tube mode. IIRC, the stereo expander had options of "off", 30 degrees, 45 degrees and 60 degrees. I preferred the 30 degrees option, followed by "off", then 45 and 60. The DSP was well implemented though. I believe there was also a bass boost with "off", 1, 2 and 3 settings - IIRC, I liked this on setting 1, followed by 2, then "off" and finally 3.
Lots of options there, which allow you to tune it to your liking.
