Nope Never.....
IIRC your amp is an op-amp based amp with op-amps in the signal path.. If so no thanks - I'll pass. But I'm sure it sounds very good, I'm just not a fan of op-amps in the signal path.
So the big question is have you heard "your" amp directly compared to an all discrete TOTL speaker amp from the likes of Threshold, Nelson Pass, Pass Labs, SimAudio, Audio-gd or our very own Kevin Gilmore - or any High end designer?
I've heard op-amp based custom amps, I've rolled op-amps, I've compared op-amp based amps with op-amps in the signal path directly to all discrete amps - many of times.
The truth is - IMO if you heard op-amp based amps with op-amps in the signal path - you heard them all. Here's why. In my experience you can have the most powerful power supply and as many watts you wish - if those op-amps are in the signal path - that's what your hearing. Many people like the sound of op-amps because you can customize the sound. Sort of like tubes - but not really.
Many op-amps carry different sound - that's why rolling op-amps is something people who like that sound do, they can taylor the sound with different op-amps.
Compared "side by side" to a "Good" all discrete amp the op-amp based amp with op-amps in the signal path lacks in transparency and clarity. From what I've heard..
Funny that u say that..that a opamp based amp cant go one on one with a good ss amp...if u did ur homework a bit my friend u should know that his amps..whether tube based, hybrid or ss..most of them with opamps in it are considered among the best EXTREME high end amps in this world... Go check the reviews about his NSL amp... But i agree...that reviewer also said ..HE WOULD NEVER EXPECTED that opamp based amp could go one on one with another (check the revie urself) reference amp he used for many years to compare High end stuff... So i can understand ur disbelieving..
Coincidence is that this weekend i am invited by a dutch high end audio shop in the south in my country to compare my amp to a couple of their high end amps (1 being discrete built, and two tube based) they sell krell and other extreme high end stuff and are getting into the headphone amp market..so they needed a reference to compare their selfmade amps to...one is going to be marketed for the high end market..thats the tube amp..the ss amp will be mid range....
It will be a friendly comparision (i bought my solid tech audio rack with them).. And am really curious how my amp compares with very good amps..i even may try speaker amps of the likes of krell. Am sure those amps (costing 10tousends of euros) will be better..no doubt..as my amp is not even 10.000euro.
But as i said...no one believes me when i say my amps sounds unbelievable...as everyone who has some experience with opamps says it cant be that such an amp sounds good..well...surprise surprise....
But check the reviews urself about their amps...google it..all their amps have opamps...some more and some less of them...but if u can believe ALL the reviews...they sound unbelievable good..no matter in which pricerange they are...
Ur in luck..ur in the states..so u could attend a audio meet where they also attend..they do that a lot...show their products on the bigger shows..maybe it would be interesting for u to try one out urself...
I was a ss amp lover, discrete builts, then i went to tube amping..the complete oposite..and now opamps... U see people can change their opinion...and i am glad i did..
I know that many people believe opamps or tube based amps are inferior sounding to discrete built SS amps, but i also believe u have exceptions to the general rule...i found at least one in the tube camp and now i found one on the opamp camp..:rolleyes:
In the end its the complete package that makes a amp sound good or not...same with cars..u can strap on a HUGE turbo on ur honda..but it will only be really fast on tracks when u upgrade the brakes, lighter rims, the shocks, transmission etc to keep it planted on the tarmac and go fast.....eventhough its generally said that a honda will be killed by any muscle car... There are excepptions to that rule
Ps..now i think of it..we had same kind of dicussion last year when i had my 'antiquated' modded darkvoice 337 tubeamp..u said same thing about that amp also.. And we proably would get same friendly discussion about my code-x, being a (according to many..faulty) he5 in the roots..but transformed to something unreal sounding by a mad genius
so i wont get into that..lolz
But am glad u stick to ur word..i respect that! More then u can imagine.
